Shock help
Shock help
Since i cranked my keys and put on the 2 inch blocks my shocks have become useless, they are extended and i need ones , I am also planning on putting ball joint spacers on it so if some one could tell me what shocks could work for me thanks
94 toyota pickup, 31's
rear - 2 inch blocks. total 2 inchs
front keys cranked 2 inchs. plus probly 1.5 inch bj spacers. so total 3.5 inchs
what shocks? thanks
what shocks? thanks
what shocks? thanks
what shocks? thanks
any shock would work....OR are you asking what size shock? If so, grab a tape measure and find out
Are you looking to maximize travel? If so, put a bunch of weight in the truck bed and cover the piston rod of the shock with a thin layer of grease, then go play off road making sure to get the rear completely flexed out. Then go home and measure the the part of the piston rod that is still covered in grease.
Say that measurement is 5". Now find a shock that when compressed is 4" longer than your current shock. Done.
The front is easier for BJ spacers, you need a shock that is something like 10" compressed, 15" extended.
dirk89
10-01-2015 05:15 PM
hiluxinargentina
09-30-2015 05:51 PM
