shifting problems - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 01-16-2007, 06:07 PM   #1 (permalink)
toy4whatever's Avatar
shifting problems
I just bought an '87 4runner (22re,5spd). First thing is the tranny doesn't fit. Let me explain, If you remove your shifter console you have the shifter boots for the tranny and t-case which has a metal piece around it. That metal piece has holes in it to screw it to the floor. Well when I removed mine there was a hole cut forward on the original and the metal piece was only screwed to the front 4 holes. How could this happen? Are some trannies shorter than others? Also I can't shift into 5th gear. Before anyone says it, the bushings are fine. Every other gear is fine. No, nothing is in the way. There is plenty of clearance around the shifter. Any of you gurus figure this out?
__________________
2007 FJ Cruiser, 3" lift, 305/65/17 BFG, custom front bumper
1990 X-cab, SAS, 1UZFE
2004 Dodge Dakota QC 4x4
toy4whatever is offline
Old 01-16-2007, 06:11 PM   #2 (permalink)
91_4x4runner's Avatar
Send a message via AIM to 91_4x4runner
What model transmission is it? Does the truck has PRND2L on the gauge cluster (indication of auto->std trans swap)? Have you tried calling/asking the PO what he knew about it?
__________________
~Eric
1991 4Runner 3.0L 4x4 Black, 31" Michelin M/S tires, OME-901's
1992 Lexus SC400 4.0 V8, Green with Tan interior (donor) (PM me for parts)
Near Future: FI 1UZ swap. (June)
Far Future mods: F/R Lockers, SAS, 35's.
UZswap.com - A discussion forum dedicated specifically to swapping UZ engines into Toyota trucks and 4Runners
91_4x4runner is offline
Old 01-16-2007, 06:56 PM   #3 (permalink)
I think I could figure that out. No. the PO traded the truck and let it set for 6 months. He never even drove it. I'm not complaing to must though, for $1800 it was a steal.
__________________
Old 01-16-2007, 07:18 PM   #4 (permalink)
Quote:
It wasn't an insult to your intelligence, merely a possible explanation.
Uness it had an engine swap where they used a different set of mounts (there are two sets on the 22re, one in front, which would put the engine back in the bay, and one in back, which would put it forward in the bay. There was a post about it a while back in the 86-95 section. If not that or a transmission swap, there should be no good reason why it would be out of place.
__________________
~Eric
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Shifting Problems - Replace Bushing? Nybbles 86-95 Trucks & 4Runners 6 07-19-2006 04:10 AM
Shifting problems moonlite 95.5-2004 Tacomas & 96-2002 4Runners 0 12-16-2005 01:26 AM
1995 4runner shifting problems CincyFreeze 95.5-2004 Tacomas & 96-2002 4Runners 10 11-12-2005 06:34 AM
shifting problems (Automatic Trans) axon Maintenance & Repair Archives 6 06-26-2005 10:20 PM
22R-E Automatic shifting problems mtbdavid 95.5-2004 Tacomas & 96-2002 4Runners 3 12-15-2004 08:30 AM
2009 InternetBrands, Inc.
