| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
Toyota 00 PU: Killed in Action - Pending Toyota 84 PU: Killed in Action ? Beach Rollover. In Surgery: LT1 Swap, New Cab, Marlin Dual Ultimate, D60s. Toyota 89 4R: Killed in Action - Dukes of Hazard'ed / Evil Knievel'ed Toyota 95 PU: Killed in Action - Retread blow-out roll over Clintimus Maxiumus Last edited by SwampThing; 01-16-2007 at 05:26 AM. |
#2 (permalink) |
Thowout Bearing
#3 (permalink) |
check to see if you clutch pedal bracket it cracked
__________________
91 pickup 22RE, 5 speed swap, 35x12.5 TriXuS M/T-SOLD! 96 4Runner Limited-FOR SALE! 07 FJ |
#4 (permalink) |
most important question is "how many miles on that clutch?"
if you are near or over the change interval, save yourself the guesswork and replace the entire thing. get an OEM toyota clutch kit or any of the other recommended ceramic ones that people seem to like (TRD or centerforce?). id just go OEM unless you wheel it really hard. my mistake was putting bandaids to mask the actual problem. here is what i did: - Redline MT-90 - clutch shift bushing - adjusted clutch pedal - changed clutch MC and SC - checked clutch bracket - changed clutch shift bushing (later went w/ the unhappy spring mod instead) ...all of which needed to be done and should be done or checked, but the thing that made 99% of the difference was replacing in the clutch kit. oh, make sure you or your mech knows what the hell they are doing. read my experience here: http://www.yotatech.com/showthread.p...t=synchronizer and finally, there's a TON of info on clutch replacements, clutch kits, etc. get r' done! bob Last edited by Bob_98SR5; 01-16-2007 at 12:24 PM. |
#5 (permalink) |
Well the clutch disc (centerforce stage 2), pilot bearing, clutch release bearing, pressure plate (oem), flywheel (resurfaced from marlin), and clutch master & release cylinders (aisin) were all replaced with whats inside the parentheses around 50k miles ago, so yeah it may be gettin close to when i'll need to replace em, but i don't think any of those components have taken a crap just yet. But I'm my own mech, and my clutch job has lasted 50k+ miles, so i musta done at lease a passible job lol.
How do I go about checkin the bracket, gotta dissconnect the master cylinder and clutch pedal assembly, or...? And just a kinda hunch, but how do you check/adjust the free-play to within spec? Thanks for the help so far folks! Keep er comin!
__________________
Toyota 00 PU: Killed in Action - Pending Toyota 84 PU: Killed in Action ? Beach Rollover. In Surgery: LT1 Swap, New Cab, Marlin Dual Ultimate, D60s. Toyota 89 4R: Killed in Action - Dukes of Hazard'ed / Evil Knievel'ed Toyota 95 PU: Killed in Action - Retread blow-out roll over Clintimus Maxiumus |
#6 (permalink) |
Look at the brackets above your left foot.There may be cracks in the sheet metal around the pedal pivot.
#7 (permalink) | |
Location: NW Ark on wooded ten acres...Ozarks at large!
Just for funsies, maybe pull a little trans. oil and check for particles. And those little clips that hold the throw out may have popped off. I'm just in the middle of doing a clutch on my '86, and when I pulled the trans. and looked at the throw out one clip was entirely gone from the clutch fork. Just a thought.
__________________
Matthew Context is everything.... Quote:
http://www.yotatech.com/misc.php?do=flashchat |
#8 (permalink) |
Well, I'll certainly try that tomorrow during daytime. I caint believe how cold it is here. Hell's finally frozen over. San Antonio is frozen solid! I aint used to this kind of weather. We like our coffee, women, and weather hot here in southern texas! lol...
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Time for a new shifter seat! | Jay351 | 86-95 Trucks & 4Runners | 21 | 06-07-2008 12:02 PM |
| MarlinCrawler Shifter Seat | 91muddog | 86-95 Trucks & 4Runners | 7 | 06-06-2007 08:47 PM |
| top shifting t-case shifter | exoman | The Classifieds GraveYard | 1 | 06-05-2006 06:43 AM |
| Shifter Seat Replacement | 93ToyKid | 95.5-2004 Tacomas & 96-2002 4Runners | 2 | 07-14-2005 12:25 PM |
| Shifter seat rip off | Swede | 95.5-2004 Tacomas & 96-2002 4Runners | 19 | 03-07-2005 05:36 PM |
