Shifters Rubbing?
Shifters Rubbing?
So after putting together my shifter assembly today (i did not take it apart) I noticed once everything was together that when the 4x4 stick is in 2H that when going into revers the 5 speed shifter rubs? Its almost like it does not want to even let it go into reverse?
Has anyone else had this issue? I am sure its a simple mistake on my side and it is the first time I have ever put these things back together. But I thought it would go much smoother?
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
Thank you guys for your info. I will try that when I get the truck back from the shop. HAd to send it in to see why the truck will not start.
That is a whole other thread...
punks_is_4x4
02-26-2016 04:29 PM
myotherrideisayoshi
09-29-2015 05:41 AM
