YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-13-2013, 09:29 PM   #1 (permalink)
Personal Sales Rating: (0)
She wont hold a charge??
hey im back with another question. first off its a 93 toyota truck 2wd 22re manual. the battery is brand new the alternator is brand new. it runs great just idles a little low sometimes. but after letting it sit like 2 days the battery is completely drained it wont do anything when i turn over the key. but i can jump start it just fine. what do you guys think is happening?
89blaster89 is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-13-2013, 10:15 PM   #2 (permalink)
Parasitic(?) drain.
Configure your multi-meter for current(amps) tests, and connect it in place of fuses in the fuse-box to find out which circuit the problem is in. Once you know which circuit he problem is in you can start debugging it.
Likely something in the light/Dome fuse circuit but just a guess.
Did you have this problem before the alt/battery replacement?
To protect your battery do the test as soon as possible, and once you ID the circuit leave the problem fuse out unless you are driving the vehicle.
__________________
Co_94_PU is offline
Old 03-13-2013, 11:40 PM   #3 (permalink)
Red face
This is interesting I have seen this problem on several vehicles that were here . It can be a drain remember there are some drains such as the clock and the radio.
For some reason up grading the ground cables has completely eliminated the problem in my case.
Of course if your leaving the glove compartment light on or the mobile boom box powered up that is a different problem.
******When you mean completely drained you measure the voltage at the battery with a multimeter and it reads zero??****
How long must you keep the jumper cables hooked up till you have enough charge to start the truck????
You changed the alternator and the battery with out replacing the old worn out cables.
If the starter is on the way out contacts getting burnt it might need that extra boost to start when it is cold.
wyoming9 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2002, 4runner, charge, toyota, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
