Shackle lift quick question
Old 05-20-2007, 06:00 PM
Shoua's Avatar
I just installed a 1 & 1/2" shackle lift on my 91' 4x4. The lift shackle came with some washers. The stock Toyota locking washer goes on the outside of the shackle, and I put the new regular "o" washers on the outside of the new shackle. My question is: do I put them on the outside (cause now I have a little bit of play between the inside of the shackle and the stock bushing)? Or do I put them on the inside and reuse the stock locking washer on the outside? Thanks in advance.
Old 05-20-2007, 10:09 PM
Shoua's Avatar
Anyone? I also noticed that because of the slight space between the bushings and the shackle, the shackle has to bend inward to the bushings. Does this bend the nut/bolt too? Not sure what grade nut/bolt came with the shackle, but the nut is a nylon locking nut...
Old 05-21-2007, 05:32 AM
MMA_Alex's Avatar
what did you get for replacement shackles? if you have the kind that are just straight bars you need to get the spacers as the shackle is offset (the spring, and shackle mount are different width)
pictures might also be helpful. its hard to understand exactly what you mean by your first post
Old 05-21-2007, 06:28 AM
4Crawler's Avatar
You can put a washer between the side plate and spring bushing if it'll help the fit. I assume these are braced shackles. Making the side plates contact the bushing flatter will help the bushings to last longer.
Old 05-21-2007, 07:28 PM
Shoua's Avatar
Yes, they are the offset and braced ones. I called the shop I bought them from and they told me they're okay the way I have them now (no spacers between bushing and shackle and shackle slightly bent inward). I would expect a little side-to-side play though. Is this okay? The shop said yes, but then again they sold them to me.
Old 05-21-2007, 10:19 PM
4Crawler's Avatar
Not sure where this play is coming from. Normally you want to crank down the bolts until the side plates make contact with and slightly compress the bushings. If there is something holding the side plates away from contacting the bushing and the springs are loose inside on the bolt, then I would add a washer or two to take up the gap. Ideally, you want the side plates hitting the sides of the bushings flush for logest bushing life. If the side plates contact at a slight angle, the flange on the spring bushing can get chewed off and then you will have some play and metal-metal contact; neither are desireable.
Flying91
45
04-11-2024 04:39 PM
coffey50
07-28-2015 10:55 AM
boogiewoogie
07-24-2015 05:10 AM
icentropy
07-14-2015 10:23 AM
Quick Reply: Shackle lift quick question
