Shacking between 50-65
hey recently i have been having a problem with my truck shaking on the highway, have no idea wat it can be, if you have any ideas please let me know here what happens:
Only between 50-65
Only when in gear and foot on gas
When in neutral or coasting it doesnt do it
Truck is a 91 3vze 4wd 5spd ext cab has 4" suspension lift and 33" tires
Thanks fro your help
Only between 50-65
thanks ill check them maybe they just have to be greased been doing alot of highway driving recently n dont remember the last time i greased the underneath, thanks for your input
could be alot of things but i would check to make sure wheels are balanced properly since you say it only occurs at a certain speed which is a symptom of bad wheel/tire balance, also least expensive to check first....G
cabbage23
7
01-02-2007 06:50 AM
881stGenRunner
05-07-2006 03:14 PM
