setting 3vze distributor
When tearing down the engine I forgot to mark the rotor position, so I set the crank to zero and the rotor on the #1 point, and now when I try to start it it only pops and backfires. Does anyone know the correct place to set the rotor too?
What he means is you have the distributor installed 180° off. So you'll need to remove the distributor, rotate the crank 360°, then reinstall it. So that the rotor is pointing at the #1 point when the #1 cylinder is at TDC of the compression stroke, instead of at TDC of the exhaust stroke.
nonstop
7
08-11-2015 09:26 AM
1, 3vze, 3zve, adjustment, destributor, distributer, distributor, distrubutor, point, posi, put, remove, rotor, set, toyota
