Sending Unit or Worse??
Old 06-28-2007, 07:07 PM
twosocks's Avatar
Coming home, this evening, running approx. 65 miles per hour, I noticed that my oil pressure was reading all the way to the left. Who knows how long it had been reading that but I didn't hear any valve noise and the temperature was correct.
When I came to my exit and stopped the needle rose to the first "low" mark and then increased more as I pulled away from the light but when approaching 45 to 50 miles per hour, the needle dropped again.
If this is pump or engine related, shouldn't I be hearing some valve noise when the pressure reads to the left?
91 4Runner, 3.0, 172k
Old 06-28-2007, 11:00 PM
Jay351's Avatar
my gauge is very wierd. It will go to perhaps the first little mark on the pressure gauge then go to like -10 while normal driving...
Has been for years.
Old 06-28-2007, 11:06 PM
Staff
DeathCougar's Avatar
check your oil? oil pressure will go down if the level is not high enough. this happened in my 88 Corolla GTS. There was not enough oil to pickup, thus pressure would go down during accel.
Old 06-29-2007, 07:35 AM
norcalsvx's Avatar
mine did the same thing when i go mudding once i cleand the connection it worked fine, you would know if you had no oil
Old 06-29-2007, 08:01 AM
ewong's Avatar
Probably the sending unit...
I put in a mechanical guage... much better. (Autometer)
Old 06-29-2007, 10:29 AM
maxpower_hd's Avatar
I've seen this on quite a few vehicles. I would be willing to bet it's the sending unit.
Old 06-29-2007, 12:57 PM
Robrt32's Avatar
sending unit.. If you had no pressure you know it quick
Old 06-29-2007, 07:51 PM
twosocks's Avatar
Thanks, for all of the replies.
kawazx636
10-06-2021 03:03 PM
Davebarbier
11-03-2015 03:28 PM
the_supernerd
10-01-2015 09:20 PM
hiluxinargentina
09-30-2015 11:12 PM
whiteyota93
09-29-2015 02:31 PM
Quick Reply: Sending Unit or Worse??
