sealant on top bolt of oil pump 22RE
Old 04-17-2016, 05:41 AM
ditypup's Avatar
Hi guys - My oil pump has a leak between the pump body and the timing cover, pooling right at the bottom center. It is not the front seal. I think it is because I didn't put sealant on the top bolt. Going to take the pump off today.
My question is. Do you all use Loctite 271 (red) or Permatex red threadlocker?
Seems to me that that would make the top bolt a real bugger to remove in the future. Wouldn't Loctite blue suffice?
What have you'all used successfully? thanks
Old 04-17-2016, 08:06 AM
rustypigeon's Avatar
Use a thread sealer, not a thread locker.
I use Permatex High Temperature Thread Sealant #59214.
Old 04-17-2016, 01:26 PM
an1176's Avatar
I believe the is an O ring around the oil pump housing. Those get brittle and flat and start to leak over time.
MudWaspSR5
03-08-2016 03:11 PM
Blissard
03-03-2016 09:17 PM
Brendan
02-28-2016 08:06 AM
BK2TFUTURE
02-09-2016 09:45 AM
litletre
11
01-29-2016 08:29 AM
Quick Reply: sealant on top bolt of oil pump 22RE
