| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
Scuba's Manual Hub Rebuild
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. |
#2 (permalink) |
Wtf ?!
Can someone tell me what im doing wrong...?
The one thats assembled will push the clutch out, but when i got to turn it back to free, it doesnt come back in...?
__________________
#3 (permalink) | |
Looks good... what color are you going to paint the selector??
__________________
Trailer Re-Build - Check it out!!! Quote:
1990 4RUNNER
V6 & 5spd. | Custom Cat-Back | Magnaflow Muffler | ProComp Light bar | OME 901HD springs | Cobra 19 Ultra III Pro comp Driving Lights | 33x10.50 BFG A/Ts | 4.88 Factory Gears | Hi-Lift Jack |
#4 (permalink) |
Hey that looks like a bit calmer conditions to do a hub rebuild. At least u dont have 40 mile per winds with sand in everything. Looking good.
#5 (permalink) |
The spring may be seated wrong. And I bought 300$ of Downey springs and u bolt flip kit and I didn't get no Goddamned sticker, fags.
__________________
"I love my 4Runner. Everyone else in my condo hates it! I guess it looks bad next to there brand new 20 or 30 thousand dollar cars that will die before my $600 Yota does, and probably before they're even done paying their cars off!" -Steveycapri Whips: '92 Xtra Cab Dlx V6, '94 Dlx I4 5spd. Camry. 98% of the teenage population will try, does, or has tried smoking pot. If you're one of the 2% who hasn't, copy and paste this into your sig. NOTE: To find the 2%...I'm the other 98%. |
#6 (permalink) | |
Quote:
And BMC...yes, alot better conditions..although, i wouldnt mind some right about now.Anyone who has done...Can you point me in the right direction as to why the clutch will go from free to lock, but wont bring the clutch back in when you go to free..?
__________________
#7 (permalink) | |
Quote:
__________________
#8 (permalink) |
Oh, and which spring are you speaking of...the big one, or little one, cause looking at the pictures, the little one is where it needs to be
__________________
#9 (permalink) |
Uploading another pic and vid as we speak....
__________________
#10 (permalink) |
__________________
#11 (permalink) |
So, i've succeeded in losing one of the ball bearings, wtf do i do now ?
EDIT: Found it, anyway, so after i switched out the ball bearing that looks like crap for one that looks perfect, its still not going back to free from lock. HELP PLEASE ??!?
__________________
Screw you guys I'm goin to TTORA Mods, please be mature and leave my sig alone, thanks. No, I will not be your friend. Last edited by scuba; 10-26-2008 at 04:32 PM. |
#12 (permalink) |
your spring is BROKEN !!!
there shouldnt be 2 pieces ...
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum Last edited by slacker; 10-26-2008 at 04:42 PM. |
#13 (permalink) |
corey, im sure its not broken, theres the little tension spring, and the big spring.
Refer to picture 1 in post one of the below linked write up.... top right theres the clutch, to the left of it is the tention spring which attaches the piece to the left of it which is the follower pawl to the clutch on the right. Then the bigger spring. http://forum.ih8mud.com/79-95-toyota...b-rebuild.html So im confused....
__________________
#14 (permalink) |
there is only 1 spring on an ASIN hub .
I dont care what that says .. there is only 1 spring . If you look closly at the spring ... you'll see where the 2 ends broke .
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum Last edited by slacker; 10-26-2008 at 04:52 PM. |
#15 (permalink) |
Not trying to be a pain buddy, and im sure you know your stuff, but do you care what the PDF says ??
http://personal.utulsa.edu/~nathan-b...14freewhee.pdf And IF it is broken it doesnt make sense.. idk...
__________________
#16 (permalink) |
yeah .. opps .. MY MISTAKE !!
sorry there are 2 springs .. it's been a while , sorry again . check this thread .. might help more then me !!!! http://www.pirate4x4.com/forum/showthread.php?t=281879
__________________
86 4x4 , fiberglass bed , 1/2 doors , hood ... more to come . 84 2WD "hotrod" Intercooled 7MGTE 83 Trekker SR5 CURRENT BUILD My home page MY PAGE 2WD fourm I frequent NEW Trekker forum |
#17 (permalink) |
lol, I was scared that was going to be the straw that made you angry...
Anyway, ill take a look at that, and try and figure this out... im getting erked, and running outta sunlight. Thanks And, if anyone has ever had this problem, please let me know what you did to remedy it
__________________
#18 (permalink) |
![]() even in my own build , I can see 2 springs .. sorry , I'm an idiot !!
__________________
#19 (permalink) | |
Super Moderator-Sponsoring Member
Staff
Quote:
![]() Is this with it installed in the hubs assembly or just the dial/face/spring/clutch in your hand? Here is how it should go together. The blue circled piece inserts through that slot with the little wound "spring" next to the dial. The flat side of the big spring goes against the pawl, not the dial. Hold the dial, insert the blue circle in the slot following the blue arrow and then twist the pawl tight up on the dial compressing the big spring. Too much grease and things won't work. If assembled correctly you can hear the pawl moving in and out when you turn free to lock. You should have gone WabFab instead of Downey for your Aisin hub needs...my stuff looks much better when you get it all assembled...those Downey bolts are cheap looking.
__________________
WabFab Off-Road, LLC MySpace 7th Annual South East 4Runner Jamboree, 2010 The toughest part of a Jeep is the chick driving it. WabFab Off-Road 4th Anniversary Sale |
#20 (permalink) |
hah, no worries.
And after reading the pirate thread nothing seems to be of problem....wtf Im contemplating sending the to the wabbit. but id like to avoid that since i bought the gaskets and the kit from downey. im angry, last night sucked, today has been pretty ghey, and the ex woman is being stupid...I told her..."im still in no mood for your rubbish" El Oh El. Anyway, /rant. Time for some self medication. *popped tab*
__________________
#21 (permalink) |
you read my mind wabb, I hope you know that was me that emailed you about the follower pawl.
Anyway, Yes this not going back in deal is with face and dial and clutch assembled in my hand, should i try putting it in the hub ?
__________________
#22 (permalink) |
BALLER!!!
Get it going, inserted it into the hub body and it locks and unlocks properly. Locked the splines will not move, Free they do. Safe to say ive go it ?
__________________
#23 (permalink) | |
Location: @ work somewhere between Walla Walla, WA and Lewiston, ID
looks like I'll be hitting the wrecking yards tomorrow sometimes. I'll see what I can come up with.
__________________
Quote:
Insomnia: it's a way of life.
#24 (permalink) | |
Staff
Quote:
__________________
#25 (permalink) |
well all is good, bout to grease it up and get it in there
__________________
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Scuba's 500ff Install. | scuba | 86-95 Trucks & 4Runners | 39 | 10-13-2008 10:00 AM |
| Manual Hub Rebuild(grease) | deSCHUTTER | 86-95 Trucks & 4Runners | 9 | 06-26-2007 08:54 AM |
| Aisin Hub Rebuild | Mudlover | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 09-27-2005 06:13 PM |
| Hub Rebuild - How difficult? | Krash | 95.5-2004 Tacomas & 96-2002 4Runners | 8 | 02-15-2003 11:18 AM |
