SAS parts interchange
Old 07-26-2009, 01:29 PM
Can'tStopThe'Yota!'s Avatar
I've got a 1986 Toyata. I'm looking at swapping out the front IFS for a solid front. I'm trying to locate a solid front from a 85 and earlier model to perform the swap with. I've got 5.29 front gears in my IFS differential housing along with an automatic locker. I dont want to have to buy new gears and lockers so I was trying to find out if the parts i currently have in the front differential can be interchanged into the new toyota solid axle. Can anyone help me out. I dont want to buy the axle and try to swap the parts if they wont fit and have to hault the upgrade. Thanks for any help.
Old 07-26-2009, 01:37 PM
toyota4x4907's Avatar
IFS fronts are 7.5", SFA are 8"
t0mwat3r's Avatar
ifs and solid axle gears/lockers are not interchangeable
Old 07-26-2009, 03:28 PM
myyota's Avatar
No way around it, you will need to buy new gears.
Old 07-26-2009, 06:51 PM
Allright. Well thats a bummer.Oh well. I guess that means ill be selling a IFS 5.29 ring and pinion gear and an auburn locker. haha. Thanks for the help guys
Old 07-26-2009, 10:30 PM
Jay351's Avatar
Any 4cyl or v6 8" toyota diff will work tho. Just so you know.
Old 07-27-2009, 07:27 AM
cblackard's Avatar
I do not think the gear sets are interchangeable, but I do not thing the SFA is an 8" housing.
The 8" housing is for the V6 trucks rear only. I think the SFA housing is either a 7.5" or 7.8" (someone confirm please?)
CB
Old 07-27-2009, 04:14 PM
yea... well i gotta figure it out what im going to put under the front end. id really like to pull the rear axle and place a Dana 60 and 66 under the front and rear... Im running 37's and i love rock crawling so i want something beefy enough to take a beating and handle these larger tires. im gonna stick with 5.29's to spin everything and i've managed to get a hold of a rebuilt Ford 302 out of a 89 mustang GT. i plan on dropping that in there as soon as i find a suitable 5 speed to mate it to
Old 07-27-2009, 04:27 PM
AxleIke's Avatar
CB
No.
Mini truck front axles are 8". As are 79-95 4cyl and V6 rear ends. They are all interchangeable.
FJ80 and FZJ80 Landcruisers also have an 8" front diff, but it is high pinion and stronger. This is the best front diff to get for a front solid axle.
Old 07-27-2009, 04:41 PM
Sponsor
Tofer's Avatar
the only thing you can reuse in the front of your SAS rig is the IFS Calipers. if you plan on getting a Trail-gear SAS kit, let me know, i am a TG dealer and i can hook you up
Old 07-27-2009, 06:29 PM
What all does the Trail-gear kit come with? i was looking at the 5 inch front sas kit from LC Engineering as i already have 5 inches in the rear... but then again i want to consider all my options for the swap.
Flying91
45
04-11-2024 04:39 PM
crashburnoveride
08-28-2015 09:20 PM
88sasturbotoy
08-11-2015 01:56 AM
Fundy Rider
07-16-2015 01:35 AM
karbin
07-05-2015 11:37 PM
Quick Reply: SAS parts interchange
