Safety Cancel?
Careful! The safty cancel button turns your truck into an animal! Just kidding, it's if you should happen to stall out climbing a hill in 4low in 1st and instead of trying to reapply the clutch and slipping down the hill, you simply use the starter to get her moving and fired up again. I use it to warm her up without having to climb in and push in the clutch.
Wow! Hey i was just gunna post the same exact question. I couldn't figure out what that silly thing was, i'd press it while the truck was already started and it wouldn't go off unless i turned the truck off. I thought i would have a good one for the tech's too...
Location: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
ding! ding! ding!
And on the subject of warming up... I used to pop my TC in neutral and my tranny in 5th (turns the slowest). So when I got out to it, my truck was warm and so was my engine and tranny...
Before, I'd get harder shifting from the thicker fluid until it warned up...
And yes, I am in the "too lazy to get in my truck to push the clutch in" category
it just allows you to start the truck without pressing in the clutch. you can also use it to get you a short distance with the starter if your craps out motor on you. hell i've seen a couple low geared trucks use the starter to climb up rocks..
I have done UNREAL stuff with my OEM starters... IMO, there is no other starter... Denso's are tha bomb! Every other starter only wishes they were a Denso...
