S10 Leaf Swap? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 86-95 Trucks & 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 12-28-2007, 05:10 AM   #1 (permalink)
91 4Runner's Avatar
S10 Leaf Swap?
I have a stock 90 4Runner (except for 33"x12.5"R15 Durango MT's, and I keep breaking upper control arm mounts off the axle. So I was at the wreckers where I came accross a 4" trailmaster IFS lift (paid $60) for everything except rear spring (broken) but I did grab the rear axle (it was on an 87 pickup) So I need leafs, so I managed to have them cut some off a 4 door S10 (aloso got a few more matching leafs just incase they aren't heavy enough for $10). So my question is this has anyone swapped in S10 springs instead of using 63" Chevys? I measured them a while ago and I believe they are 59". I did put one under my axle (frame to frame with the center pin about centered on the axle) and it hangs about 2" lower than the axle - so as long as they don't go negative I think they sould give me close to 4" of lift... I hope..... What do you think? Thanks for any help.... Larry
__________________
Mostly Stock 90 4Runner SR5 V6 Auto w/ 33" Durango MT's (bent lower valance removed), bush bar w/ 55w Baja Offroad Lights, Custom fit 1st. gen rollbar (used to mount Hi-Lift and fire extinguisher), extended diff breathers, (Comming soon rear spool and 2" body lift..)
My very slow buildup on Sontt.com - currently building.
http://www.sontt.com/forum/viewtopic...&t=109&start=0
91 4Runner is offline
Old 12-28-2007, 05:55 AM   #2 (permalink)
FrmrJPGuy's Avatar
My first thought would be that the S10 leaf springs will in no way be the same as the Full Size Chevy springs. You gotta figure the FSC is either a 1/2, 3/4 or 1 ton and the S10 is a mid size pick-up. Totally different from each other in weight and towing capacity.
IMOP I think you may want to go back out to the salvage yard and find the FSC springs that you need. The S10 may work but they are probably going to settle and not be able to keep your rear end at the height you are looking for.
__________________
FrmrJPGuy
Tampa, FL
99 4Runner Limited, Deck lid mod, 265/75/16 BFG A/T, Rancho RSX
94 Wrangler, 4" lift, 33X12.50 TSL Radials
FrmrJPGuy is offline
Old 12-28-2007, 07:57 AM   #3 (permalink)
yeah the s-10 springs might be enough for lift but the weight capacity is going to be way lower than the fullsize chevy springs. the other option would be to combine spring packs (you said you got multiple) to build a pack that will better hold the weight.
MMA_Alex is offline
Old 12-29-2007, 04:11 AM   #4 (permalink)
91 4Runner's Avatar
That's why I got other springs, but I was also thinking about getting FSC mains and custom pack it...
__________________
Old 12-29-2007, 10:09 AM   #5 (permalink)
seafarinman's Avatar
Send a message via AIM to seafarinman Send a message via Yahoo to seafarinman
S-10 springs are very soft like the 88-98 1/2 ton (63") springs. However, they are really thin and break easily. The 63" FSC springs are flexy but really only work with a lot of weight in the back which is why the guys with 4Runners love them. They don't work as well on pickups. And they don't give more than 3" of lift without shackles, or blocks.
__________________
DEPLOYED Again!
1994 SAS 2RZ/R151F=244:1!
1988 Toyota 4Runner SR5
seafarinman is offline
Old 12-29-2007, 10:22 AM   #6 (permalink)
Luvmeye22re's Avatar
I think they will work just fine for you. You may need to add a leaf or two for your 4Runners heavy fat ass. If they measure 59" that is a good length I think because you won't have your rear shackle bashing on rocks nearly as much as a 63" Chevy spring would. Also Marlin's rear springs are what, 57 or 58 inches long? That tells you something right there. They'd probably make 63 inch springs if they thought it was more beneficial.
__________________
86 Runner with rebuilt 22re and 5 speed swap
Luvmeye22re is offline
Tags
4runner, baja, customs, leaf, leafs, mount, road, s10, sale, sizes, springs, swap, tacoma, tampa, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
leaf spring swap bull307 86-95 Trucks & 4Runners 1 09-14-2007 02:56 PM
Try and Keep 4link or do leaf swap?? 4Runner92sr5 Solid Axle Swaps, All Years 13 08-23-2007 08:49 AM
chevy leaf swap? hirsche23 86-95 Trucks & 4Runners 3 04-30-2006 11:53 PM
Leaf spring swap... pretaco 95.5-2004 Tacomas & 96-2002 4Runners 2 08-22-2005 07:22 PM
which leaf springs to swap? fryeguy1983 Offroad Tech 5 01-08-2005 03:22 PM
2009 InternetBrands, Inc.
