RV6 Idling High
Old 06-17-2009, 04:44 AM
Azabache's Avatar
RV6 Idling High
Hello all,
4Runner, 1993, RV6 3L, manual
A while back ago i took my rig to the mechanic to get a rusted plug replaced at the back of the cyl. head, so he had to remove all the intake system.
Now when I start it cold in the morning it idles at 1000 and as it warms up revs climb to 1500rpm and they won't come down unles I drive it for about half hour (it would then drop to around 1200).
When engine is warm, I shut it down and re-start it after 15-20 minutes and it would idle nicely at about 500-600 but in a matter of minutes rpm's would slowly rise to 1100 or 1200 and stay there as long as engine runs
*Idle speed screw is all the way in
*TPS screws still have original paint from factory
*I cleaned around the throttle plate without removing the TB and it looks like it's closing fine
Any advice or ideas would be appreciated
Thanks in advance guys
Old 06-17-2009, 07:19 AM
abecedarian's Avatar
Sounds to me like either the air valve under the throttle body may be sticking or there is a significant vacuum leak.
Old 06-18-2009, 05:21 AM
Azabache's Avatar
I thought it could also be a stuffed temp sensor since the temp almost reached the red before all this started to happen
Old 06-18-2009, 03:54 PM
Azabache's Avatar
Yeah, thanks for the info fellas, it's good to be here
tomczaksdiesel
07-26-2015 10:35 PM
Cbr954ryder
07-25-2015 06:32 PM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
luckypig44
07-19-2015 11:25 AM
kyletbert
07-17-2015 11:39 AM
Quick Reply: RV6 Idling High
