RV2 can install question
Old 05-17-2015, 09:25 AM
Josh_Br's Avatar
Hi,
I'm working on a 1992 22RE. The truck is a 1990 4x4, reg. cab. I've got the engine torn apart to replace the head gasket and timing chain. I've been thinking about putting in an RV2 camshaft from yotashop.com. I have never changed a cam before.
With the engine already apart, is installing a new cam as simple as basically unbolting the old and replacing it with the new, then adjusting the valve clearances when I put it back together, or is there more to it? I also have new head bolts to use when I reassemble.
Thanks
Old 05-17-2015, 09:52 AM
skypilot's Avatar
No it really is that simple when its torn down like that. Now I use Delta Cams regrinds so far so good, much better than stock profile.
I have a 272 cam going in the new engine, and I think a 260 in the other truck. The one really does idle nice. The 272 is for play. You really don't want to stray far from a good idle. Radical profiles are for competition, leave them at the track.
Old 05-17-2015, 09:59 AM
Josh_Br's Avatar
That's good news -- thanks. I was just wanting to make the truck a little more fun for everyday driving. I agree regarding idle; a good idle is important. Which of those two cams would you suggest (260 or 272)? Thanks
Old 05-17-2015, 11:57 AM
skypilot's Avatar
The 260 is a hoot, fun to drive and practical. The 272 engine is sitting on an engine stand, I should know by winter. I expect the 272 to be more of a hassle due to higher lift and duration and behave more like a muscle car.
Old 05-17-2015, 01:42 PM
Josh_Br's Avatar
Great - thanks for your help!
Old 05-18-2015, 04:46 AM
Josh_Br's Avatar
I ordered a cam last night, a Delta 272. When I install it, do I need to use any special lube, or just engine oil? I know I've heard of cam lube, but am not sure if that's necessary.
Thanks
Old 05-18-2015, 08:15 AM
skypilot's Avatar
Yes; there are special cam lubes for solid tappet cams like the 22re series I got mine from Grumpy's place on ebay. But you can use engine assembly lube, red sticky stuff.
Old 05-18-2015, 08:25 AM
Josh_Br's Avatar
Ok -- Thanks again
Old 05-19-2015, 07:34 AM
skypilot's Avatar
A shameless plug for Delta cams, got a bent cam from them a while ago. Well they just replaced it with no hassles or fuss. Just got the replacement Fed Ex today.
Kudo's for them!
Old 05-19-2015, 08:22 AM
Josh_Br's Avatar
Good to know, just in case.
Old 05-24-2015, 02:35 PM
Josh_Br's Avatar
I have this week off work and am hoping to get a lot done on the truck. So if I swap the camshaft, put the new sprocket on it, and install the new timing chain, how do I know I have the new cam in the correct position? The crankshaft is still at TDC on the compression stroke. Thanks again
Old 05-25-2015, 08:05 AM
skypilot's Avatar
Colored links go over the dots on the cam gears. Check my photo library for pic's. Just finished mine, tore out a camshaft bearing cover bolt. Got lucky and got it fixed.
Old 05-25-2015, 01:31 PM
Josh_Br's Avatar
Thank you, didn't realize the crank sprocket also had a marking. Speaking of the crank sprocket, I found that the old one was missing a few teeth! Nice
tj884Rdlx
08-28-2015 12:04 PM
Poppie51
07-23-2015 05:03 PM
rushw
07-18-2015 01:46 PM
Poppie51
07-16-2015 06:16 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: RV2 can install question
