Rusty fuel pump bracket removal
Old 09-21-2008, 03:26 PM
rustypigeon's Avatar
Hey guys. I have the bed of my truck off to repaint the frame. I am looking at my fuel pump bracket and it is caked in rust. I am wondering who here has removed this bracket and how did you get the rusty bolts off. It looks to me like I am going to have to drill and extract each one. There is hardly a head left on any of the bolts. I don't need to remove the bracket any time soon thought I hope. But when it comes time for a new fuel pump this does not look like its going to be fun at all.
Here is a pic of my bracket, I can't seem to get a picture in this post....
http://i535.photobucket.com/albums/e.../rustyfuel.jpg
Old 09-21-2008, 03:33 PM
rngrchad's Avatar
I just went through this exact problem with my mother's 97 Honda Accord.
I was able to remove all of them using a small #2 Craftsmen Bolt Out. I did have to drill one out with a small left hand drill-bit but once you get the head's off all of them came out really easily. I think you'll be suprised how easy they'll come off. Spray them with copius amounts of your favorite penetrating oil.
Old 09-21-2008, 03:52 PM
Did you only have one bolt head snap off? Looking at mine, I am kinda thinking they will all snap off.
Old 09-21-2008, 03:54 PM
YotaJunky's Avatar
spray it down with pb blaster and then take a vise grip to it. I had the same issue.
Old 09-21-2008, 03:56 PM
rngrchad's Avatar
You'll just have to give it hell there Pigeon and see what happens. Spray your pb blaster on it. Give it time to soak in and then use a really small bolt-out designed for stripped heads on philips screws to run them out. You can buy a small 1/4" drive bolt out kit at sears. The kit will be with the the building tools not in automotive.
I only broke one head off...and after it broke off it was really easy to get out.
I hope yours goes as well as mine did. Good luck bro.
Old 09-22-2008, 08:47 AM
PCE91V64x4's Avatar
My fuel pump bracket was rusty but to my amazement the bolts came out without breaking. Since you have the rounded off heads I would use the above advice and use a lot of PB blaster over the period of a few days and then use the bolt outs to get the bolts off.
Old 09-22-2008, 08:58 AM
Squiddy's Avatar
The bolts usually come out VERY easily after some PB blaster.
See my write up: https://www.yotatech.com/forums/f116...nsight-131902/
Old 09-22-2008, 05:21 PM
I finished painting the frame today. I am wondering if I should replace this bracket before I put the bed back on. Looking at the picture, do you guys think mine is close to springing a leak?
I would just replace it anyway but I just spent $300 for a new rear bumper.
Old 09-22-2008, 06:05 PM
SteveMcQ's Avatar
I would definitely change it. Those hard lines out of the cover are garbage. I changed mine when I built my bed and smeared the new one with grease so I didn't ever have to mess with it again.
Spray it down with PB and give them a try...usually when they break, there is enough to get a visegrip on the bolt thread to turn them out.
Old 09-23-2008, 06:41 AM
slacker's Avatar
I just did this ...
https://www.yotatech.com/forums/f116...ghlight=por-15
I used vice grips to "crack" them loose and they came off quite easliy .. it was the pressure line that is/was the problem .. There was NO way I could crack it loose , as it torqued to ~ 40ft/lbs at the factory .
Old 09-23-2008, 08:57 AM
Well, I decided to bite the bullet and by a new bracket and related parts. What started out as being a $70 frame painting project turned into a $600 project. I decided a new bumper was needed since the old one was rotten and the bolts snapped trying to remove it from the frame $300. Then I got looking at the fuel pump bracket and decided it was looking like it was going to spring a leak soon, another $300.
The parts will be at the dealer in the morning, I am soaking the bolts in penetrating oil in the meantime.
Old 09-23-2008, 09:37 AM
RobD's Avatar
Yeah, after laying out that much money, you're going to need lube for more than just removing rusty bolts.
Old 09-24-2008, 05:38 PM
Well, the job is done. POR15 the frame, new bumper, and new fuel pump bracket. Like you guys said the fuel pump bracket bolts came off very easy with a day soaking in penetrating oil. I would have never thought bolts that rusty could come off without snapping. I think my bracket was very close to developing a leak because a crack developed when I took it off. The pipe was about as thin as a soda can in the area.
I didn't need to use the high pressure hose I bought, as I was able to disconnect the old one. Just a note for anyone doing this, I used 14mm and 19mm crows foot flare nut wrenches with foot long breaker bars to disconnect the high pressure line. I don't think I would have been able to disconnect the coupling without these as it was rusted pretty good.
POR15 frame....
http://i535.photobucket.com/albums/e...styfuel001.jpg
New bracket....
http://i535.photobucket.com/albums/e...styfuel002.jpg
New bumper...
http://i535.photobucket.com/albums/e...styfuel003.jpg
Old 09-24-2008, 08:24 PM
YotaJunky's Avatar
nice job!
Old 09-25-2008, 06:45 AM
mistreatedtoys's Avatar
I have had to do this before a couple of times as they make so many different fuel pump brackets. Just remove the rusty pressure line by drilling it out. Replace with a piece of 1/4 brake line. Remove the brake fitting and replace it with a fitting of of a Ford PVC tube. You can find those in that section of the Auto parts store that have all of those "HELP" parts.It is a maetal tube about 5" long with a fitting on it. This is the same as the fuel line fitting and only cost a couple of dollars. You can replace all of the tubes and fittings for about 15 bucks.
Old 09-25-2008, 01:43 PM
streetlancer's Avatar
I had the same problem with my 87. I could smell the gas but had no idea were it came from. So i took the bed off and saw those gas lines on top of the tank were rusted. They looked pretty bad and one was completely rotted and had a leak. So i took it of and one bolt broke but i was able to get it out. The lines cost me $28 from toyota. Nice Job on the painted framed.
Old 09-25-2008, 03:25 PM
Cyberman's Avatar
I replaced mine too, the hard line was in 2 pieces, and looked like swiss cheese. The bolts came off easily, even though they looked the same. Although, my fuel pump bracket was only a little over $100. Did you get a new pump as well? Mine also had shorter hard lines.
Before:
After:
Old 09-25-2008, 04:30 PM
My bracket was $160, the high pressure hose was $65 (which it turns out I was able to keep the old one on), and the gasket and bolts were another $10. When I picked up the parts they gave me a 25% discount for some reason. I thought real hard about replacing the pump, but I didn't want the spend another $250. I figured now that the bolts have been replaced I can pop the bracket off pretty quick if I need to. Did you guys put new pumps in when you replaced the bracket?
Old 09-25-2008, 04:35 PM
slacker's Avatar
my pump was ok ... so I reused it ...
BUT for future RE & RE .. did you NEVERSIZE the new connections ??
Old 09-25-2008, 04:42 PM
Cyberman's Avatar
My wallet was empty, so I reused the pump...
Quick Reply: Rusty fuel pump bracket removal
