Rustbullet
Old 02-25-2008, 09:18 AM
Gavy's Avatar
Rustbullet
Hey guys heard alot of good things about this rustbullet so i just purchased a starter pack of the auto grade stuff to give it a try my truck is actually in really good shape for the most part but I have some rust ob both sides back by the mudflaps and I know if you kep letting it go it will creep up on you and be alot worse so I'm trying to take care of it before hand. Is there anything special i need to do or any tricks to this stuff or is it just mix and paint on?
Old 02-25-2008, 01:19 PM
Nothingface5384's Avatar
i'd atleast try to sand off/grind off all the rust you can, then apply the rust bullet, putty if needed then primer and paint!
Old 02-25-2008, 02:09 PM
swerks's Avatar
Any one try this stuff ??? http://www.kbs-coatings.com/
I have used the rust bullet it does work well but I am always looking for better options.
Old 02-25-2008, 06:16 PM
nope, i'll probly use chassis saver....same specs are por-15 but a tad cheaper
Old 02-25-2008, 08:10 PM
87toy.'s Avatar
i pulled the top if the window rubber off my truck today, looks like ill be useing some of that, lots of rust...
Old 02-25-2008, 08:22 PM
312necro213's Avatar
Por 15 it and watch the rest of your truck rust around it
Gavy
07-25-2008 05:01 AM
Turd Ferguson
04-17-2008 04:48 AM
Yota Tony
02-11-2007 02:59 PM
gohawks
01-15-2006 07:18 PM
gohawks
06-08-2005 04:09 AM
Quick Reply: Rustbullet
