Running without a belt
Old 12-18-2009, 04:05 PM
Paulsky's Avatar
1991 22RE. My air conditioning belt broke off. It runs straight off the main shaft without any other accessories on that belt. I shouldn't run into any problems running without it, right? I just won't have air conditioning, which given current air temperature is not an issue. Am I thinking straight? If anyone is aware of any possible damage I could inflict by doing this, let me know.
Old 12-18-2009, 04:25 PM
whokrz's Avatar
Should be fine just make sure the tensioner part can't unscrew its self and fall off while you are driving it.
Old 12-18-2009, 04:51 PM
streetlancer's Avatar
You will be just fine.
I am currently in the same boat only difference is I don't have power steering either.
But that is due to a noisy idler pulley that i will soon be putting back on.
By the way does anyone know the order the pulley goes in??
I was too lazy to take pictures and forgot the order, there is 1 flat washer, 1 lock washer, a nut, and which way does the pulley go?
Old 12-18-2009, 04:53 PM
TOYOTA 1's Avatar
watch out, your pants might fall down!
Old 12-18-2009, 05:11 PM
BigBluePile's Avatar
HA! You beat me to it!!
You could say you caught me with my pants down...
Guess I should buckle down next time...
Old 12-18-2009, 05:30 PM
stormin94's Avatar
I heard the defroster uses the A/C compressor to remove the moisture out of the air. I'm not sure if there's anything to that, but maybe the defroster won't work as well.
Old 12-18-2009, 05:51 PM
Ha! Ha! Ha!
Doug4320
03-24-2018 10:11 PM
Amer
3.4 Swaps
19
06-05-2017 10:43 AM
dinks07
07-15-2015 05:34 PM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Running without a belt
