running with the tps unhooked?
Old 06-07-2007, 03:16 PM
shugashaft's Avatar
i have unhooked my tps sensor since i couldnt fix the idle and guess what it doesnt surge and run like crap anymore. maybe later ill replace it but for now its all good. what will it hurt with it unhooked. or what am i lacking?
Old 06-07-2007, 03:40 PM
yotasavg's Avatar
that's strange.....mine wouldn't even run with it unhooked.
Old 06-08-2007, 12:15 AM
shugashaft's Avatar
mine runs just fine i still have a high about 1600 idle but i think i can back the throttle adj screw back some.
Old 06-08-2007, 02:37 AM
TNRabbit's Avatar
The TPS is used by the ECU to correct timing, fuel delivery, etc., and a multitude of other things. It WILL run without it, but not well. You really need to replace it.
Old 06-08-2007, 05:36 AM
85TurboRunner's Avatar
my truck will RUN fine without it hooked up but it has absolutely no power if i try to accelerate. i bet your running way rich with it unhooked.
Old 06-08-2007, 06:52 AM
netwt12's Avatar
my bet is you'll be replacing some fouled out spark plugs in the near future.
Old 06-08-2007, 11:04 AM
midiwall's Avatar
Ditto on my 3.4...
Old 06-08-2007, 01:29 PM
shugashaft's Avatar
i have alot of power still even at 274k mi with it unhooked
Old 06-09-2007, 06:06 AM
gametom's Avatar
what motor do you have?
Old 06-09-2007, 10:09 AM
isenegger's Avatar
3.0...........
smthwsn357
12-04-2023 02:08 AM
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
Doug4320
03-24-2018 10:11 PM
88yodabasket
07-13-2015 01:32 PM
Quick Reply: running with the tps unhooked?
