Rumbling sound front passenger
I have a rumbling sound coming from what sounds like the passenger front end at 15 mph and again but quieter at 25 mph. It gets much worse if I am turning left. Could be some sort of vibration.
Replaced CV's, ball joints, and wheel bearings in the last month. Ideas?
was it there before you replaced those parts? i'd jack up the front end and shake it down to make sure wheel bearings are still tight. do you have auto locking hubs or manual?
turning left puts the weight of the vehicle on the passenger side. sounds like a wheel bearing issue kind of. when you replaced the wheel bearings did you install new races? were the old wheel bearings pitted?
The wheel bearings I removed looked fine. Spun them over and no noise. I did not install new races. Looked inside and didnt see anything terrible. I didnt have any races at the time and the current ones looked ok.
Check spindle bearing and bushings that sounds like the same problem i had they dry out and then loosen up and allow the cv shaft to move around through it. As a tempoary fix use a grease needle take apart your hub and inject it till it comes out around the sides once you do that you shouldnt be able to move the cv shaft up or down.
Parts Needed
Roller Needle Bearings, 2ea- Toyota Part Number: 90364-30011
Inner Steering Knuckle Bushing, 2ea. Toyota Part Number: 90381-32001
Toyota Chassis Grease, 1oz Tube. Toyota Part Number: 08887-80219
https://www.yotatech.com/forums/f128/steering-spindle-bearing-replacement-2nd-gen-4runner-76360/
Parts Needed
Tires were the issue. You dont even want to see the way the front two were worn.
Some new claws fixed me right up!
Only issue is the shop says steering components were too worn to do a proper alignment so I guess these will suffer the same fate.
Good thing I am picking up a solid axle tomorrow!
WTB[WestCanada]: 1989 4runner stock front bumper and other items
lledwod
08-30-2016 01:03 PM
09-04-2015 09:27 AM
crashburnoveride
07-10-2015 06:39 AM
