RPM jump with steady increase in throttle
Old 10-24-2009, 02:24 PM
sv-tex's Avatar
Exclamation RPM jump with steady increase in throttle
I have a '90 Pickup, V6, 4x4, manual trans. When i press the accelerator slowy from idle the RPMs get up to around 1500 and then immediately jump to near full throttle. What could be casuing this? TPS? Throttle body? Vacuum? I have been searching and cannot find anything on this. Thanks.
Old 10-24-2009, 02:26 PM
Kiroshu's Avatar
sounds like tps to me.... any codes?
Old 10-24-2009, 03:29 PM
ski187's Avatar
Sounds like your clutch is gone, the same thing happened to me. One day it worked then the next day i was going skiing and the rpm's shot through the roof when i hit the gas. There was a little resistance at first then the rpm's climb up.
Old 10-24-2009, 03:32 PM
Kiroshu's Avatar
Wow i didn't thnik about clutch slipage..... that is indeed possible. Are you drving down the road or taking off and all of the sudden you stop moving but ur motor is reving? thus may be time for a clutch.
Old 10-24-2009, 04:12 PM
sv-tex's Avatar
it happens even in neutral. sitting still, slowly pushing the accelerator and then bam, the RPMs just go way up. no slipping of the clutch, although i'm sure it is pretty worn (like everything on this truck)
Old 10-24-2009, 04:15 PM
Kiroshu's Avatar
yea i'd say tps...... does it have any codes?
Blamalam
03-12-2022 07:34 AM
utahman
08-23-2015 02:04 PM
mtc1105
08-04-2015 08:06 PM
altydog
07-28-2015 10:20 AM
greenbuggy
3.4 Swaps
07-23-2015 11:51 AM
Quick Reply: RPM jump with steady increase in throttle
