rough starting
Old 09-29-2011, 12:43 PM
summit4runner's Avatar
rough starting
Finished a rebuild a while back and everything is great except for starting. I had a mechanic set the timing.
When I start it initially in the morning, somtimes, it sputters a little and check engine stays on a little longer than normal.
If I give it gas as I start it it's fine. Once it's warm and I start it, it's fine.
I remember a screw on the top of the air intake manifold for fuel, should I try adjusting that? I've made small adjustments to the timing but it's the same.
Old 09-29-2011, 12:54 PM
sechott's Avatar
Injectors maybe clogged, low fuel pressure or clogged fuel filter. Any of these could cause fuel atomizing problems especially in a cold engine.
Old 09-29-2011, 01:05 PM
Should I try a fuel system cleaning additive, or does that have the same negative effects such as radiator stopleak and stuff like that.
I'll replace the fuel filter as it's only $12, injectors are quite a bit more.
So, the screw on the intake manifold is a no go?
Old 09-29-2011, 01:25 PM
BMcEL's Avatar
Sounds like the cold start injector. Testing procedure is in the factory service manual.
Old 09-29-2011, 02:12 PM
sechott's Avatar
I am not familiar with the screw in the manifold, Also I am new to these trucks so I was going by experience with other vehicles I owned. Referring to a previous post the cold start injector is probably the place to start.
sandyota
02-04-2021 11:16 AM
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
raiderhawks00
07-08-2015 06:23 PM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: rough starting
