Rough Idle
Old 04-10-2006, 01:38 PM
ramrugby09's Avatar
Rough Idle
I have an 86 4Runner with a 22RE. I just put a brand new OEM TPS in and set it per the instructions I found on this site. This has fixed my transmission problems. Before I put in the new TPS I was getting 7 blinks from the check engine light which is the TPS. Now that I have replaced it I am getting 11 blinks, what does that mean? My problem now is that when I stop for a light or something the idle is very rough, like it is missing. If I sit at the light for lets say a minute the mis works it self out and it idles perfectly. Any ideas?
Old 04-11-2006, 09:36 AM
ramrugby09's Avatar
Anybody have any ideas?
Old 04-11-2006, 09:51 AM
YotaJunky's Avatar
Did you set the timing after doing the TPS. If you can't set the timing, then your TPS may not have been set correctly.
Troy
Old 04-11-2006, 11:09 AM
ramrugby09's Avatar
I havn't tried to set the timing. The truck runs perfectly when I start it up and itermitantly at lights.
Sleaker
08-26-2020 06:03 AM
Eggslinger
06-08-2019 03:32 PM
1992pickupSr5
05-09-2019 08:44 AM
TACOJO
11-27-2015 05:26 PM
markwink
08-18-2015 12:38 PM
Quick Reply: Rough Idle
