Rough Idle - YotaTech Forums
Go Back   >
Rough Idle
LinkBack Thread Tools Search this Thread
Old 10-13-2005, 03:32 PM   #1
iGGz's Avatar
Rough Idle
Alright the ol 4Runner is starting to idle a little rough like it almost feels like its going to die but then when I give it a little gas it sounds fine... but it will just keep going in and out...
I actually had to put it in nuetral a few times at the stop signs to keep it from dying...
Oh and also the engine is clicking like hell when I accelerate... what could be the cause of that...
Sorry so short have to run to class!
Thanks
iGGz is offline   Reply With Quote
Old 10-13-2005, 05:10 PM   #2
Elton's Avatar
maybe a vacum leak or just needs a tuneup
Elton is offline   Reply With Quote
Old 11-03-2005, 06:04 PM   #3
iGGz's Avatar
Alright I havent even driven it for like 2 weeks now because there is no need to... but I went outside to the parking lot to drive it around for awhile and when I would stop at a stop sign it would just idle horrible and actually sound like it was going to shut off... the lights and everything seemed a little more dim too... and it actually did die when I got back to the parking lot...
Hum...
Old 11-04-2005, 12:29 PM   #4
iGGz's Avatar
Coughhh
Old 11-04-2005, 12:37 PM   #5
Intrepid's Avatar
My '85 will pull strong on the highway no problem but when I let it drop to idle it stalls. If I ease off the throttle gently it will stay running most of the time but if I just step off the gas and let the RPM's drop it will stall. I haven't figured it out yet. When I do, I will let you know.
Intrepid is offline   Reply With Quote
Old 11-04-2005, 12:41 PM   #6
Intrepid's Avatar
Rough idle mystery Eggslinger 86-95 Trucks & 4Runners 17 01-18-2017 06:03 PM
87 4Runner Rough Idle/Misfire issues Sleaker 86-95 Trucks & 4Runners 11 03-26-2016 05:12 AM
Engine bog down / power loss TACOJO 95.5-2004 Tacomas & 96-2002 4Runners 8 11-27-2015 06:26 PM
rough idle t100 3.0 markwink Newbie Tech Section 1 08-18-2015 01:38 PM
Rough idle after motor swap! 1992pickupSr5 86-95 Trucks & 4Runners 0 08-06-2015 11:43 AM
Tags
1985, 1995, 4runner, 91, 96, 98, drops, fix, idle, idles, idling, rough, toyota, tundra, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
