roof rack on 95 4runner
Old 08-27-2009, 12:12 PM
ET
ET's Avatar
i have a 1995 4runner that i purchased and doesn't have a roof rack. is it possible to install a stock rack onto it without too much fabrication? i have a thule set now but they clamp into the door jambs and if i get a basket then it would cover up the moon roof.
thanks for any help.
Old 08-27-2009, 12:25 PM
mitch101's Avatar
It is possible but very expensive. Afterthought roof rack installs are also known to leak if not done right. If it was me i would get someone to do it that will waranty their work.
Old 08-27-2009, 05:55 PM
ET
ET's Avatar
lol, such as the dealership. right hahahaha
Old 08-28-2009, 08:34 AM
mitch101's Avatar
Try body shops. They are cheaper than dealers and usually stand behind their work. You may have a hard time finding one to do it though.
Old 08-28-2009, 08:43 AM
nevermore1701's Avatar
What about baskets that mount where the factory roof racks go and don't block the sunroof?
Old 08-28-2009, 08:50 AM
NYChopshop's Avatar
uhhh... drag your butt to a junk yard and remove the roof rack from a wreck. I believe it should be a matter of a couple of holes. do some searching on the subject. There are plenty of other threads about it already.
https://www.yotatech.com/forums/f116...f-rack-145998/ ... for one...
https://www.yotatech.com/forums/f116...f-rack-176750/ ... also...
oh, you can also shell out the hundred-and-some-odd-bucks for the Yakima 54" tracks, part #8001127.
Old 08-28-2009, 08:59 AM
NYChopshop's Avatar
match them rails with a load warrior basket. You can keep those over the rear. Again, do some searching - there are PLENTY of threads not only on Yakima Load Warriors, but on any flavor of roof basket for our rigs.
Old 08-28-2009, 09:13 AM
Jay351's Avatar
Factory roof rack.
I bought one for $50, gonna install soon.
Drill your holes, pop in rubber well-nuts and screw your bolts in. Done!
Old 08-28-2009, 10:03 AM
RobD's Avatar
Originally Posted by Jay351
Factory roof rack.
$50? Must be a BC thing. I got mine at the local Pick 'n' Pull for $16.99.
There are 8 bolts, if memory serves, and like Jay said, drill some holes and use nutserts or rivnuts http://www.enfasco.com/frame4.htm (Google them) to fasten it to the roof. You might want to consider some silicone around the nutserts.
BushPig
10-29-2022 06:26 AM
icentropy
09-16-2020 02:47 PM
BeMiceElf
10-10-2015 09:40 PM
HaydenConQueso
07-12-2015 05:22 PM
Quick Reply: roof rack on 95 4runner
