rolled on paint
Old 03-07-2007, 08:45 AM
  #41
all_terrain17's Avatar
This has been my Spring Break project - Dad's old 92' Ranger. Sanded it down with 60 grit and then again with 120. Just started painting on it this morning.
Something tells me it's been in a wreck sometime in its life
Think I got it on the hood a bit thick first time around. Gonna let it set and see what I need to adjust...
Should be done by tomorrow night with two coats.
Old 03-07-2007, 09:04 AM
  #42
Rcross's Avatar
Here is my truck sprayed with the Rustoleum Professional Safety Red
I have just under $100 bucks invested in this paint job.
Old 03-07-2007, 10:24 AM
  #43
shoes138's Avatar
damn i wish i would known this a long time ago, so i didnt have to pay for a damn paint job!
Old 03-08-2007, 12:47 PM
  #44
GunNut's Avatar
Nice Job rcross & allterrain!! I have to look into what color I'll be painting on. and now that the weather has gotten better, I think I'll get started on it soon.
anyone else have other colors they want to share? Post your photos!
Old 03-08-2007, 05:10 PM
  #45
Putting on the 4th coat tomorrow morning and then lightly wetsanding with 1000 grit...Only problem I've had is that the scratches from sanding with the 60 grit show through on the first couple coats. Hopefully it's now thick enough to hide that. Funny thing is I haven't used much at all. Maybe 1/5 gallon so far with 3 coats.
I'll get some final pics tomorrow if I can get the thing back together in decent time.
Old 03-08-2007, 07:19 PM
  #46
gotboostedvr6's Avatar
Heres my $200 paint job
This is as bad as the peel gets
Old 03-08-2007, 07:22 PM
  #47
That house was exactly 175 feet from the truck so you can tell the peel isnt really that bad
i did all the prep work myself
wet sand 400 then 600 bondo and full primer coat
payed a buddy with $30 beer and the 2 half gallons of of paint cost $170 100 base 70 clear and i have a bunch left over
Old 03-08-2007, 07:46 PM
  #48
Aaronb's Avatar
looks good. Im getting my paint next monday.
Old 03-08-2007, 11:51 PM
  #49
shoes138's Avatar
thats a damn good job! now all you gotta do is color sand it then it will look great! what kind of paint did u get n did you just use like a roller that u use for walls like the wool ones?
Old 03-09-2007, 12:00 AM
  #50
bob200587's Avatar
Nice wheels, same as mine. I rarely ever see those exact ones.
Old 03-09-2007, 02:01 PM
  #51
that paint job was sprayed on using dupont base then clear
Old 04-29-2007, 11:09 AM
  #52
Lysmachia's Avatar
Well all - looks like after I get my axle doe and tippy back I will have a week where I can do the roll on method (for the base coat) and then start masking off for my Moab camo. I am cueious to see if I can use the roll on method for the camo spots too. We'll see....
I was told to use "Dupli Color - by Paint shop" What did each of you use? I am looking to get a maroon red, (base color) light greym dark grey and black. I want all of them to be flat but I am not sure I can get those colors in flat...
Old 04-29-2007, 12:29 PM
  #53
swerks's Avatar
I used good ole Rustoleum but that dont leave much for color options
Old 04-29-2007, 05:58 PM
  #54
tc
tc's Avatar
Does anyone make a matte clearcoat?
Old 04-29-2007, 06:53 PM
  #55
4Rocker's Avatar
Wow, perfect time for this thread to come back up. My truck was recently vandalized with paint stripper (after painting it a few years ago!!!!) so I need to completely repaint the whole truck. I picked up a gallon of Rustoleum Safety Red and have been testing this method on a spare door, so expect to see a thorough writeup soon in the 84-85 section...
Old 04-29-2007, 08:05 PM
  #56
Rcross's Avatar
If you are spraying the Rustoleum Prof. oil based paint I recommend putting it on very thin. If you spray it on too thick it wont harden very well, the exterior layer will harden while the inner layer will stay wet for awhile leaving the paint soft. I put about 12 layers of super thin paint with about 6 hours between coats and it hardened very well.
Old 04-30-2007, 05:59 AM
  #57
Lysmachia's Avatar
Next week while Troy is in Hungary I begin my Moab Camo paint job. Looks like I will use the roll-on method of a a maroon red for the base coat and then do camo spots in another shade of red, lighter grey and black. Haven't gotten everything nailed down yet but it is getting there...
Color Ideas....
ashamsuddin
17
01-13-2023 03:17 AM
kawazx636
10-06-2021 03:03 PM
ladybugRC
458
08-21-2020 10:41 AM
83yotastockR
11
11-10-2015 06:54 AM
PNW94Runner
09-29-2015 02:55 PM
Quick Reply: rolled on paint
