rolled my 86 22re
rolled my 86 22re
ok i rolled my 86 toyota pickup extra cab and broke the front windsheild and dented in the roof. should i get a whole new cab? or do some body work? and if i get a new cab will an 87 fit on my 86?
Check all the fluids, make sure the battery is in good shape, put the lugs back in and fire it up. It's going to smoke like a fiend for a little while until it burns the residual oil out of the cylinders but it should be fine.
dont turn it without topping the fluids especially oil.
if you turn it with too much oil in the cylinders you can bend a rod. i hope you shot the oil out before you tried turning it
The starter motor won't have enough juice to bend a rod. Oil has drained from the tappet cover through a couple of those vacuum lines into the intake. Pull the plugs, crank the motor and oil will be ejected from the cylinders. After that's done, put the plugs in and fire it up. it'll smoke a little, but don't sweat it.
09-04-2015 09:27 AM
DrZero
18
07-24-2015 11:31 PM
94yotaky
07-23-2015 07:50 AM
