Roar in right front end
Old 01-08-2013, 01:36 PM
DavidPayne's Avatar
I have a 91 4wd pickup. When the weather is nice and warm outside I never hear this noise but as soon as the temp drops down close to freezing I get a roaring noise on the right side of the front end. I replaced the wheel bearings at the last brake job and that didn't help. With the wheel off and when I shake it everything seems tight. Maybe the CV shaft? Thats what im thinking. Any ideas? Thanks in advance for any help.
Old 01-08-2013, 01:39 PM
HighLux's Avatar
Bet its the tire
Old 01-08-2013, 01:43 PM
DavidPayne's Avatar
Not the tire. Have replaced the tires and still have the noise.
Old 01-08-2013, 02:03 PM
snobdds's Avatar
It's not the tire...
It's your spindle bushings. They need to be greased, however there not easy to grease. Sleeoffroad has a great little tool for this and, ironcally, I just ordered one. Mine will start to make a bad noise when it's cold out and my hubs are locked, which is the only time the front CV's turn. I unlock my hubs and it goes away...therefore I know its the spindle bushing. If you have the ADD hubs, your CV are always spinning and the bushing goes out a lot quicker.
http://www.sleeoffroad.com/products/...ol_detail.html
Christo shows using it on a 100 series landcruiser, but the spindle is the same between the landcruiser and our generation of trucks.
Old 01-09-2013, 09:16 PM
Andy87's Avatar
You can make your own tool pretty easily too... and you won't need to remove or re-set your axle nut. Scroll down towards the bottom of this thread for pics:
https://www.yotatech.com/forums/f116...27/index2.html
Old 01-10-2013, 04:35 AM
waskillywabbit's Avatar
This.
:wabbit2:
Old 01-10-2013, 04:39 AM
92 TOY's Avatar
hmmmmm. subscribed. my son's 4runner is doing the same thing. i thinks.
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: Roar in right front end
