rinngin rich and pinging
Old 02-21-2009, 10:40 PM
94toy4x4fever's Avatar
Ok so some of have read my past post on my 94 toyota pickup (22re) with egr problems egr is fine did all the test, and pinging! i have fixed all issues! All vaccum lines are hooked up right. Im still having pinnging problems. Anyone have a clue what might be going on? injectors havent been touched. Running ngk g power plugs and a 180 degree t stat. I dont know if any of this info would help or what not. thanks guys
Old 02-21-2009, 11:11 PM
toyota4x4907's Avatar
Your timing is probably too far advanced....what kind of condition is your coil, igniter, wires and everything relating to that in?
Old 02-22-2009, 12:04 AM
mikesnyhere's Avatar
my 90 22re was running rich and pinging wouldnt pass smog .the shop diagnosed and fixed it .they replaced the o2 sensor and found 2 vacum lines swithed that went to the egr.are you getting any codes ? that might help diagnose itgood luck with that.
Old 02-22-2009, 02:23 AM
sas'd22re's Avatar
anyone have the vaccum line diagrams for 22re's? mines an 86 and would just like to check and make sure that their hooked up right
Old 02-22-2009, 07:10 AM
fdeeznutz's Avatar
It's in the FSM(you can download here) or on the sticker under your hood.
Old 02-22-2009, 11:33 AM
Engine has less than 4,000 miles on it! New plugs,wires. Ignitor isent new and coil is either. Timing is set to 5* tdc with timming jumper installed! Could I try and set the timing to 4* or 3* to see if it will go away? Any long term effects if the timing is not set at stock settings? O2 sensor is also new.
Not getting any codes.
Old 05-15-2009, 10:17 AM
***Bump***
Longbed 90
03-11-2019 12:38 PM
Longbed 90
10-19-2015 11:05 AM
Shaun Crystal Gomban
09-20-2015 11:16 PM
accuracy
09-20-2015 07:44 PM
Boomer8404
09-10-2015 09:01 AM
Quick Reply: rinngin rich and pinging
