Ring and pinion
Old 01-19-2012, 04:25 PM
Utah4Runner86's Avatar
Ring and pinion
I need to regear my front diff - will a 4.3 ring and pinion from any 7.5" diff work as long as it's not reverse cut? No yards in town have 4runner/truck gears, but one has 4.3 gears from the back of an old Supra - will they work?
Old 01-19-2012, 05:27 PM
MudHippy's Avatar
So I've been told. I've never tried it, but I used to have some 7.5" 3.58s out of a 92 2WD PU laying around. And they looked exactly the same as the 4WD 7.5" 4.10 ring and pinion I compared them to side by side. Anyhow, I'm pretty sure it's been done without complications...or we'd have heard something by now...that's how I know that all 7.5" carriers aren't compatible BTW...been tried already...with limited success...
Old 01-19-2012, 07:25 PM
snobdds's Avatar
They should. I believe the 4runner also came in a 4.30 on a auto tranny and the 28 inch tire option.
http://www.4crawler.com/4x4/4R_TechInfo.shtml
Old 01-20-2012, 03:12 AM
Yeah, mine is the the auto with 4.3 gears. I replaced the front diff, and the gears are wrong.
Thanks guys!
Old 01-20-2012, 02:46 PM
ZUK
ZUK's Avatar
Your front diff has 7.5" low pinion 4.3 gears....I just found out and edited this... some of the 1985 Supras/Celica's do have the 7.5" ring gear (I have one on the work bench right now5-9-12).
ps----If you need it, I have a low pinion 7.5" 4.3 ring and pinion for 75...shipped to slc.
ZUK
Old 01-20-2012, 04:30 PM
Originally Posted by ZUK
Your front diff has short pinion head 4.3 gears....I think the 4.3's from rear-end applications are long pinion head...so that might not work out for your front.
ps----If you need it, I have a short 4.3 ring and pinion for 75...shipped to slc.
ZUK
You got a deal, thanks gear man! PM comin' your way.
kawazx636
10-06-2021 03:03 PM
dzldust
7
10-06-2015 05:39 AM
hiluxinargentina
09-30-2015 05:51 PM
charlie_fong
09-27-2015 10:06 PM
Odin
09-26-2015 06:56 PM
Quick Reply: Ring and pinion
