Is this the right seal? Rear axle.
Old 04-18-2013, 11:04 AM
ConvertedYotaMan's Avatar
I picked up a rear outer axle seal from napa. It looks like this which is a little different than I've seen online. 10 bucks
Thanks!
Old 04-18-2013, 11:29 AM
wolf28's Avatar
looks like the drum brake seal if ur looking for the seal that goes inside the axle housing that is the wrong one
Old 04-18-2013, 11:33 AM
˟˟˟˟. So this isn't the one that keeps oil from going all over my tire? Is that one called the inner seal?
Old 04-18-2013, 11:57 AM
wolf28's Avatar
no cuz I made the same mistake when I bought my seals I forget wat its call but its the axle housing seal the ones u need look like this http://www.marlincrawler.com/images/rearseal_500.jpg
Old 04-18-2013, 12:01 PM
damn alright ill head back there and see what else they got. thats the one that goes on the outermost portion of the rear axle housing correct?
Old 04-18-2013, 12:03 PM
wolf28's Avatar
correct once u pull the axle shaft out of the housing the seal will be right on the out side of the housing
Old 04-18-2013, 12:08 PM
wolf28's Avatar
try the dealer that's where I got mine
Old 04-18-2013, 12:32 PM
i wish we had a toyota dealer around here. i gave napa the part number and it finally came up. it should be here in 2 days. where the hell does the seal i returned go then?
Old 04-18-2013, 03:56 PM
wolf28's Avatar
I have know idea where the seal that u got goes I got the same seals in my tool box.. I thing there suppose to be a seal that goes in between the brake drum and axle housing
im not sure.. im sure someone will chime in about where it goes
Old 04-18-2013, 06:32 PM
Punchy's Avatar
There is another seal that is just an Oring, About 3-4" dia 1/8 thick, This goes between the axel housing and the brake backplate.
Old 05-09-2013, 03:14 PM
Tkelly55's Avatar
How hard was the axel to get out of the rear end mine is leaking and I'm stuck
Old 05-09-2013, 08:53 PM
85TurboRunner's Avatar
Four nuts and remove the brake line from the wheel cylinder and it slides right out.
Very easy.
Edit: Undo the e-brake cable also..
jerusry
10-19-2015 05:28 PM
88sasturbotoy
08-11-2015 01:56 AM
colasurdo
07-16-2015 11:32 AM
Iceman4193
07-15-2015 04:48 PM
andrewtexas123
07-14-2015 04:29 AM
Quick Reply: Is this the right seal? Rear axle.
