Reverse lights stopped working
Old 12-25-2009, 02:16 PM
foskco87's Avatar
At first they would just flicker on and off while i had it in reverse and now they just dont come on at all. I highly doubt its the bulbs being out so it must be a relay or the switch in the gear shift? Has anyone encountered this before? Where do I start?
Old 12-25-2009, 03:01 PM
myyota's Avatar
There is a reverse light switch screwed into the side of the transmission, check to see if the switch is working.
Old 12-25-2009, 03:03 PM
tc
tc's Avatar
Check the bulbs first.
Old 12-26-2009, 02:35 PM
cholbach's Avatar
Just finished fixing the same problem on my 86 runner. Automatic or manual??
Old 12-26-2009, 02:39 PM
AzStorm's Avatar
What TC said.
I had this happen recently to my truck.
One brake/turn/tailight and one reverse bulb were out.
I replaced ALL the bulbs and all is well.Everything works as it should and I dont have to worry about the wife raggin on me about getting a ticket.
Bulbs are cheap and readily available at your nearest auto parts store.
Old 12-26-2009, 02:52 PM
foskco87's Avatar
Ok thanks guys, ill check the bulbs first but if its not that its probably the switch. Im pretty sure its the switch because the lights would flicker on and off and basically just started being on less and less until they never come on. Oh and its a manual tranny.
Old 12-26-2009, 04:17 PM
bain's Avatar
my old truck did that and the wires on the trans were old and coming loose
gillesdetrail
11-19-2019 12:56 PM
camdenbuck
07-07-2015 07:33 AM
aciorba23
06-29-2015 04:18 PM
cchinny
06-25-2015 08:11 PM
gog1968
06-22-2015 05:55 AM
Quick Reply: Reverse lights stopped working
