Reverse light question/repair.
Old 12-08-2009, 10:52 AM
cholbach's Avatar
Did a lot of searching the past few days and have not been able to find an answer or help. I have an 86 runner, automatic, Reverse lights work rarely. Trying to find out where to start. Any wiring diagrams or other trouble shooting idea's would be great. Both bulbs are good so I know it isn't that. All help and suggestions welcome.
Old 12-08-2009, 11:55 AM
interested2meet's Avatar
Not sure as it changed yr by yr, if you have a manual transmission the reverse switch should be on the side, screwed into the case. Jump the wires together if the lights come on you got it.
Old 12-08-2009, 12:02 PM
cholbach's Avatar
it is an automatic. Not sure what I am looking for. PS has a connector with 2 wires coming off it, but not sure that is it.
Old 12-08-2009, 12:22 PM
cholbach's Avatar
Not sure if this will help anyone help me, but I am visual so here are a couple of pics of the connections on the tranny
Attached Thumbnails Reverse light question/repair.-closest-engine-ds.jpg   Reverse light question/repair.-ds-back.jpg   Reverse light question/repair.-ps.jpg
Old 12-08-2009, 12:23 PM
spdjnky's Avatar
there is an adjuster on the pass side of the transmission. Don't have any pics, but I couldn't get it adjusted when my lights would hardly ever come on so I just wired up some fog lights in the back for reverse lights.
Old 12-08-2009, 12:37 PM
cholbach's Avatar
I am going to put on some lights for extra lighting, but have to eventually fix back-up lights for inspection
Old 12-09-2009, 01:07 PM
cholbach's Avatar
Tried to trace wires with no luck. Did find that the rear defrost wires had broken free from the connecters. Fixed that now back window only works with key. Trying to fix one thing leads to having more things to fix!!! Still no luck with the back-up lights
Old 12-13-2009, 03:49 PM
cholbach's Avatar
O.k. I have discovered what I believe to be the switch and will post pic. No power reading from wire. Can not find relay. What to look for next? Any HELP???
Attached Thumbnails Reverse light question/repair.-switch.jpg
Old 12-14-2009, 01:00 PM
cholbach's Avatar
Anyone? Anyone at all? Where is the relay forward of the switch? Where do I go next???
Old 12-14-2009, 05:57 PM
Skoalbandit's Avatar
what year/make? go to an auto parts store website, or search google, find a pic of the switch and match it to a similar switch on the tranny. if there is no power coming out of the switch (assuming you had it in reverse when checking the wires) replace the switch, it's possible it's trash after hundreds of thousands of times of going into reverse over the years.
Old 12-14-2009, 06:04 PM
camo31_10.50's Avatar
anybody have the harness that connects the 4wd indicator light and the reverse light switch to the rest of the wiring??? i guess mine got ripped off one day?
my buddy's '86 4wd 22re has the wires going into a harness that is over the tranny..
i just can't find it anywhere around here lol
*EDIT* sorry about the thread jack dude lol
AkitaDog
09-01-2015 08:05 AM
Shaun Crystal Gomban
07-30-2015 10:13 PM
rchavis
07-27-2015 07:41 AM
Poncho0206
07-10-2015 06:21 PM
madxman21
07-09-2015 10:26 AM
Quick Reply: Reverse light question/repair.
