Reusing Timing Belt Hyraulic Tensioner
Old 02-06-2011, 07:35 AM
drmix's Avatar
I am just about done with doing my HG and I replaced the timing belt as well but I was wondering what everyone uses to get the pin back into the hydraulic tensioner? The manual calls for using a press to push it down enough to get the pin in. Is there any way I could do this without using a press?
Old 02-06-2011, 07:48 AM
blake.nemitz's Avatar
i just loosen the bolts and and when you crank it back in the pin pushes in
Old 02-06-2011, 07:57 AM
95blackToy's Avatar
x2 I just put it back on and when you tighten the bolts it pushes back in and tensions.
Old 02-06-2011, 08:33 AM
DJ99's Avatar
I used a vise and squeezed it slowly until I could get the pin through it. After reinstalling it, the pin gets pulled out.
Old 02-07-2011, 06:49 AM
fjmudder1's Avatar
I did the same thing on a new tensioner I accidentally let go on.
Considering the situation, possibly a new tensioner is a good idea?
fjmudder1
Eggslinger
06-08-2019 03:32 PM
09-04-2015 09:27 AM
nick b
07-11-2015 04:38 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Reusing Timing Belt Hyraulic Tensioner
