Retrofit Tach Wiring Help
Old 01-01-2011, 09:27 PM
TheDean's Avatar
Hey all, I'm a stickler for needing to know what's going on in my vehicles, and not having a clue on most of the vitals on my 92 xtra cab (automatic, v6), is killing me. I have a mini generic tach that I used in my 67 impala, and the wiring it in isn't really an issue, but which wire on the ignition system to splice into is the problem. My Haynes manual was less than informative in the wiring diagram section, so I was wondering if you guys could help me out as to which wire to splice the tach onto. Also, if wanting to I stall an additional coolant temp guage, (for the exact graduated number) in conjunction with the factory guage in the cluster (keep both operational) would I use the stock yota sending unit -wiring and splice it to the new guage? Or do I need to find a place to install the new guages sending unit? Where is the temp sending unit? Ps, as a side note, what is typical winter gas mileage with the auto/v6 that you guys have gotten? I realize my 31x10.5's do decrease it, but 400 km to a tank when driving nice is brutal (I sea foamed the intake). Thanks guys, cheers!
The Dean
Old 01-01-2011, 09:29 PM
TheDean's Avatar
*install an additional coolant temp guage. Apologies, auto correct on my iPhone can really bite
Old 01-01-2011, 09:47 PM
justin_4runner's Avatar
for the tach wire i go easy and just attach to the coil area. makes it easyer then trying to find the wire in the dash area.
Old 01-01-2011, 09:53 PM
TheDean's Avatar
That was my plan, I'm just confused about which wire exactly on the coil to splice into, and I dont quite wanna go hack at it with a machete until I know exactly which one lol
Old 01-01-2011, 10:21 PM
i want to say its the positive side, the way to figure it out is pull plug and use a volt meter and see.. as for the coolant gauge i would say that u would have to install the sensor that came with the gauge and not the factory one. might send different volts to run it.
Old 01-03-2011, 12:59 PM
TheDean's Avatar
Stupidly, I should've known it was the positive! Gotta stop second guessing myself! I'll let you know of the outcome when it warms up enough to do it! Thanks, Dean
Old 01-03-2011, 01:57 PM
dreadnotmusic's Avatar
The tach signal comes from the NEGATIVE coil side. You'll likely ruin the tach if you try it on the positive.
Old 01-04-2011, 03:58 AM
TheDean's Avatar
Knowledge, ftw (for the win)!!! Thank you, good thing it's still frozen out and haven't gotten the inspiration to fix it yet eh haha! And yes, I just said eh
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
sanctfy
All Other Toyota Swaps
09-15-2015 02:52 PM
Daneums
07-28-2015 11:57 AM
altydog
07-28-2015 10:20 AM
80Truck
07-24-2015 03:12 PM
Quick Reply: Retrofit Tach Wiring Help
