Replacing oil pump/oil pan - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 03-29-2010, 02:44 PM   #1
Could someone let me know for sure if I have to remove the oil pan in order to replace the oil pump?? - it's a '94 22RE - Not that I can't remove the pan, I removed it twice in the past five months (replacing rod and main bearings) and would like to avoid doing it again if I don't have to. Thanks much.
Nogarage is offline   Reply With Quote
Old 03-29-2010, 03:00 PM   #2
xxxtreme22r's Avatar
you do not have to remove oil pan, oil pump is connected to timing cover and crank.
xxxtreme22r is offline   Reply With Quote
Old 03-29-2010, 03:04 PM   #3
4Reigner's Avatar
You do not need to touch the pan, you don't even have to drop the oil.
Radiator, fan and belts need to come out, and the pulley comes off, then it's 5 bolts that hold the oil pump to the timing cover.
Pack the new pump with grease, sealant on the top oilpump bolt, and reassemble everything.
Easy fix!
4Reigner is offline   Reply With Quote
Old 03-29-2010, 03:16 PM   #4
Philbert's Avatar
If you haven't already, you may want to just do the timing chain and water pump while you're at it. You can even do that without dropping the oil pan. Every 100K miles is the guidance I believe....
Philbert is offline   Reply With Quote
Old 03-29-2010, 08:13 PM   #5
thanks for all the input! AND QUICK, TOO!! It's so much easier to confront a chore when I know what it's gonna take. Especially with No Garage.
Old 03-29-2010, 08:47 PM   #6
Magnusian's Avatar
Location: Downtown Heckronto, Ontario, Soviet Canuckistan
Quote:
I think it's closer to 140k miles on the lower-end of the scale but I've seen a few 22Rs that went far beyond that before getting a new timing chain, depends on driving habits I suppose.
Magnusian is offline   Reply With Quote
Old 03-29-2010, 10:41 PM   #7
I just did this yesterday. I didn't drain the oil and left the radiator in. I removed the fan and belts. I'm guessing about 1/4 cup of oil spilled out of the pump when I removed it. Have some towels handy.
If your crank pulley is grooved from the oil seal, consider installing a seal of different thickness to ride on an unworn part of the pulley. Some links about that:
http://www.yotatech.com/f114/22r-fro...81-2wd-126295/
http://home.earthlink.net/~twopapa/toytech.htm#seal
My pics from yesterday: http://www.yotatech.com/51404425-post381.html
The top bolt gets some sealant. My manual says torque that top bolt to 18 ft/lbs. The other upper two get 14 ft/lbs., and the two shorter ones neareast the oil pan 9 ft/lbs.
Pack the pump with Vaseline or grease. Wipe a little grease on the seal lip. Some grease also helps hold the pump's o-ring in place as you put the pump on.
flyingbrass is offline   Reply With Quote
87 22r rebuild issue bigjstang 86-95 Trucks & 4Runners 14 12-09-2016 10:16 PM
Do I bother fixing it? 1993 3vz-E 4x4 Colington 86-95 Trucks & 4Runners 13 07-21-2015 06:24 PM
Here come the bearings.... Gamble_STi 86-95 Trucks & 4Runners 2 07-07-2015 08:54 PM
4runner stalling in gear... Do this again please Jnkml 95.5-2004 Tacomas & 96-2002 4Runners 3 07-06-2015 02:20 PM
New AC Questions (Not the same old ones) HRDC0R19 86-95 Trucks & 4Runners 3 07-05-2015 07:43 PM
Tags
2000, 22re, 97, cavalier, chain, changing, connected, oil, pan, pickup, pump, replacing, ring, timing, toyota
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
