Replacing Fusible Link
Old 08-29-2007, 01:41 AM
Gadgtgal's Avatar
Hi, I can see my Fuse is blown.. 1992 4Runner V6
How do I get to the 80A fusible link in the engine bay area? I understand it is held in by screws, but what do I need to do to the main fuse box area to get it out? Thanks.
Old 08-29-2007, 07:53 AM
eric-the-red's Avatar
You have to seperate the top of the fuse box from the bottom. I think the two pieces just clip together.
Old 08-29-2007, 07:38 PM
brandyn85's Avatar
yeah the bottom just clips off and you have to push the fuse through the bottom and there is a 10mm and a 8mm bolt on there holding the wires on i believe
Old 08-29-2007, 07:44 PM
deathrunner's Avatar
Just don't pry at it. I busted mine up a month ago.....I'm a dumbass
You need to unbolt it from the bottom side.
Unbolt the whole fuse box, then it should be easy to seperate the fusible link portion.
Old 08-31-2007, 07:13 PM
GenXr's Avatar
X2 word for word!! I pryed at mine and busted it up last month to. Definitely unbolt the box from the fender. Nobody mentioned this but you should really disconnect the battery first.
sandyota
02-04-2021 11:16 AM
mskalmus
05-28-2017 07:51 AM
TURBOrunnerNM
07-22-2015 11:01 AM
razorman8669
07-12-2015 12:13 PM
ptb12
07-05-2015 01:49 PM
Quick Reply: Replacing Fusible Link
