replacement engine
Old 09-16-2008, 01:02 AM
ibornagain's Avatar
replacement engine
I have 86 toyota 4x4 with 22r engine...I don't have the funds to rebuild this one but might have enough to buy a used running one...what year do I need to look for so that I can keep the swap the simplest? any advice would be helpful...
Old 09-16-2008, 03:39 AM
Gizler00's Avatar
I have a 22re from an 88 with 130,000 miles on it. Ill sell it for 200$$ Where are you located
Old 09-16-2008, 03:53 AM
Yoda's Avatar
A 22R from 84 to 87. You could use a RE model if it has the fuel pump mount on the head. You would have to swap over your intake/carb to the replacement engine.
NOTE: If you go to your User CP, you can add your state or city, etc to your data. Makes it easy to tell where people are located.
Old 09-16-2008, 06:17 AM
Staff
DeathCougar's Avatar
Any 22R/22RE from 85-95 will work, with a few minor adjustments such as intake, wiring, fuel pump, and fuel pump eccentric (if using an EFI engine)
Old 09-16-2008, 07:53 AM
ibornagain's Avatar
Roanoke, Alabama
voiddweller
19
05-02-2016 09:10 PM
Ichneumon
09-27-2015 04:21 PM
Jmiller1023
23
08-06-2015 07:03 PM
Jnkml
07-06-2015 01:20 PM
Vargntucson
07-04-2015 12:15 PM
Quick Reply: replacement engine
