Replaced injectors now wont even crank
I have a 86 22re that had 2 bad injectors. It would still crank and run but not well. I replaced them last night and now it will not start. I double checked to make sure all wiring was hooked up and all lines good. Any thoughts would be greatly appreciated.
"Crank" usually means the starter will turn the engine over. I'll bet you mean it won't "fire," meaning the starter turns it, but you don't hear any combustion.
Pull the plugs. If they are dry, you're not getting any fuel. If they're wet, you're not getting any spark.
Thanks, I found a broken ground wire for the injectors. I am now afraid that i have "trash" in the system. I have ran it only a few days and now one of the injectors has stopped working. Going to find out which one today and hopefully clean out what ever it is.
steve miller
10-10-2015 01:40 AM
TURBOrunnerNM
07-22-2015 11:01 AM
