Replaced 3.0 head gasket now engine wont start.
Old 06-03-2013, 09:33 PM
Dutch1023's Avatar
I bought an ''89'' 4 Runner with a blown head gasket. Had a buddy rplace the head gasket,timing chain and gears now the engine won't start just turns over and acts like it wants to start but nothing. Has spark and fuel. Can't figure it out.
Old 06-04-2013, 06:02 AM
2toys's Avatar
Try rotating your distributer 180 degrees you can put it in backwards happened to me.
Old 06-04-2013, 06:04 AM
2toys's Avatar
Or your buddy didn't get the cams or the crank set at tdc. Only a few things it could be if it ran before
Old 06-04-2013, 06:47 PM
Dutch1023's Avatar
Thanks for the input. Seems to want to fire every once in a while but nothin happens. Should I just turn the distributer or cap as well?
Old 06-06-2013, 06:47 PM
Dutch1023's Avatar
89 4 runner
Got the distributor turned 180 degrees still wont fire. I just checked the fuel rail and has pressure for a second and then nothin. Turn on the key and still nothin, turn the key to fire it up and a little fuel spits out. wondering if the fuel pump is bad? any thoughts?
Old 06-06-2013, 07:01 PM
Scrussanation's Avatar
here ya go http://personal.utulsa.edu/~nathan-b...87fuelpump.pdf
Old 06-06-2013, 07:14 PM
Dutch1023's Avatar
If the fuel pump is bad there wouldn't be any fuel correct?
Old 06-06-2013, 07:23 PM
not necessarly.. they can become clogged and still pump but not at what they should, alot of factors come into play the link i sent you gives you the order of checking. its from the toyota service manual fsm
Old 06-06-2013, 07:30 PM
scope103's Avatar
... I just checked the fuel rail and has pressure for a second and then nothin. ...
Do you have the intake hooked up? If there is no air flow through the VAF the fuel pump shuts off as soon as you let go of the key.
Old 06-07-2013, 07:31 PM
Dutch1023's Avatar
89 4 runner
Hooked up the intake hoses, Now I am getting back fires and blow backs through the intake. Scared the BJESUS out of my wife.
Old 06-07-2013, 08:02 PM
thats awesome lol
edit:the 2nd part that is
Old 06-07-2013, 08:22 PM
Dutch1023's Avatar
89 4 runner
It was priceless. I don't know what was better the look on her face or finally getting the 4 runner to do something other than just turn over. Wish I would of had a video camera.
Old 06-07-2013, 08:27 PM
id love to have been there lol
naward1996
04-23-2018 05:23 PM
voiddweller
19
05-02-2016 09:10 PM
paxanders
06-21-2015 06:29 AM
yamaha73
06-18-2015 06:19 PM
Mutinebullfrog
06-18-2015 01:36 PM
Quick Reply: Replaced 3.0 head gasket now engine wont start.
