Replace my own alternator?
Old 08-14-2007, 02:26 PM
TheHulk94's Avatar
Is it difficult to replace my own alternator? I have very limited experience on engine work.
I have a 94 Toyota PU 22re 5speed.
I tried searching for anything related to replacing the alternator and didnt find anything that was quite in terms that I could understand or thought was useful. Any help is greatly appreciated!
Thanks.
Old 08-14-2007, 02:49 PM
MMA_Alex's Avatar
its definately doable. its just a matter of getting under there to get it unbolted.
take a look, and see if you can figure out how to get at all the bolts.
Old 08-14-2007, 03:48 PM
ovrrdrive's Avatar
Super simple job... One bolt in the top, one in the bottom. One plug in the back and one nut on the battery wire.
Most find it easiest to remove the lower radiator hose to get it out from the bottom. And yes, you have to drain the rad to do that.
Just be sure to unhook the positive battery cable before you start and you shouldn't have any problems...
Old 08-14-2007, 04:41 PM
linuxrunner's Avatar
Not a difficult job, but i did have to drain the rad to get it out. People kept telling me it was possible to do without removing lower rad hose, but i don't know how i barley fit with the hose out... And i had to do it in the snow by the side of the road
Plus to make matters worse the alternator that i got was rebuilt and the threads in the alternator that are for the bolt you use to tighten the alternator belt back up were not there at all, just a smooth hole, so after filling the rad back up and getting everything hooked up i had to remove everything and start all over again
But it was not difficult just took longer than our other cars.
Old 08-14-2007, 05:35 PM
rdlsz24's Avatar
The only bad part is having to undo the lower radiator hose like everyone above says.
Rob
Old 08-14-2007, 07:24 PM
nmtoy's Avatar
I have done it on 2 different trucks without removing the lower radiator hose. It takes some doing but I always take it out from above.
Good luck!
Robb
Old 08-14-2007, 07:53 PM
hmmwv15's Avatar
No need to remove the hose as long as you can muscle it out. Really simple job and I learned the hard way to remove the batt. cable...
Old 08-14-2007, 08:43 PM
hodgepodge79's Avatar
I once did mine in a motel parking lot with the the skid plate and radiator hose still on. Not hard at all.
Old 08-14-2007, 09:15 PM
Slednutjetskier's Avatar
I have a complete steering system from an 86 IFS Pickup if you need it.. Check my thread "Parting out 86 Pickup"
Old 08-15-2007, 12:49 AM
ovrrdrive's Avatar
How does that help this guy that wants to change his alternator?
Are you suggesting he cut out his steering to make the job easier?
Old 08-15-2007, 05:53 AM
Flash319's Avatar
I find is easier to just take the fan off (4 bolts) and slide the Alternator through into the fan shroud and out the other side by the throttle body. No coolent to deal with.
Old 08-15-2007, 06:07 AM
rdlsz24's Avatar
lol I was wondering the same thing.
Rob
redneck17
10-29-2015 09:09 PM
09-04-2015 09:27 AM
msane99
07-17-2015 10:13 AM
1994toyota
07-17-2015 03:03 AM
colinmil
07-06-2015 04:03 PM
Quick Reply: Replace my own alternator?
