Removing xtra cab rear trim
Old 05-31-2013, 01:42 AM
Latigo's Avatar
Hey all, I'm restoring an 87 pickup and am trying to remove the interior rear side panels that go from floor to ceiling and surround the rear windows.
Any clue on how to remove this? Feels so brittle I'm afraid to break it. There's gotta be better way, right?
Thanks!
Old 05-31-2013, 02:45 AM
85TurboRunner's Avatar
Have you removed all the other trim pieces that hold it in. The xtra cab windows need to come out. The rubber trim around the doors needs to come off. And Im sure theres more. Its been a while since Ive pulled the panels out but it was pretty easy from what I remember.
Old 05-31-2013, 06:37 AM
slacker's Avatar
they are super brittle ....
you have to remove the 1/4 window first , then the panels are "taped" (double sided tape) on . there is a strip down the front edge and around the window edge .
we now have these avaliable new
Old 05-31-2013, 07:18 AM
RSR
RSR's Avatar
With trim, this will save your trim and your pocketbook a load of hurt: http://www.harborfreight.com/5-piece...set-67021.html
Old 05-31-2013, 09:43 AM
Latigo's Avatar
Thanks for the quick responses! If my trim breaks in the process, I've been eyeing those fiberglass pieces for sure! But I'd rather buy something I want (like that fiberglass windshield visor) than something I need because I broke mine haha.
So anyway... removing the window. How do I do that? I'll search just in case it's been answered.
Old 05-31-2013, 02:36 PM
RSR
RSR's Avatar
1985 FSM -- download it while it's up. Basically, it just directs you to the back window directions. Pull the weatherstripping and then remove any screws holding the glass in I guess. My 93 quarter windows open and assemble differently.
http://htftp.offroadsz.com/marinhake...985FSM_OCR.pdf
Old 05-31-2013, 03:01 PM
The window basically just pushes out sorta. You have to work around the edge and push the rubber seal out.
Its kinda like taking a bicycle tire off the rim.
Old 05-31-2013, 05:20 PM
Latigo's Avatar
Aha! Got them out with a pry bar and strong language!
Thanks for the help everyone, this forum is great Hopefully it goes in easier...
lledwod
08-30-2016 01:03 PM
Nickdigg
07-07-2015 06:04 AM
Steezy96yota
07-06-2015 10:00 AM
coryc85
07-06-2015 04:07 AM
elwood73
07-05-2015 07:07 AM
Quick Reply: Removing xtra cab rear trim
