Removing tailgate lock cylinder
Old 06-25-2009, 04:41 PM
blue_CA_yota's Avatar
How do I remove the lock cylinder from the rear plate light bar? The black plastic piece which says Toyota..
I've got the plastic piece off the tailgate, and have taken out two small phillips head screws, but I can't figure out how to get the lock cylinder out of it. It looks as if the outside chrome ring needs to come off, so the cylinder can pull through the backside.
Old 06-25-2009, 04:44 PM
Marc's Avatar
Are you're talking about the lock cylinder that make the tailgate window go up and down?
If it's like my 90 there is a clip on the inside that has to be removed.
Old 06-25-2009, 04:52 PM
that is the lock I'm talking about
There doesn't appear to be any clips.. I can't pull the lock through the front because of the shape of the plastic cut out.. I can't pull the lock through the back because the chrome trim ring won't fit through the hole.. I believe I need to separate the two pieces, but I don't know if there is a trick/method to doing this to save me from mangling the two pieces or break the very fragile plastic.
Old 06-25-2009, 05:17 PM
slacker's Avatar
NO ...
dont pry or pull ...
just like the ignition cyl .. there is a "pin" you need to depress . But , because this thing has been in the door so long with no attention .. you will nead to soak the crap out of it just to see it . wire brush might help .
once you have located the "hole " for the pin .. you'll need a small drift to "punch" to dissenguage the pin .. then it will come out easy peasy .
the hole size is minuet about the size of a pen refill ..
Old 06-25-2009, 05:38 PM
Thanks Slacker
I came across that pin, and I thought that must be whats holding it together.. however when it didn't budged I assumed there was more than one of them.. Good to know its just on the one side.. I will soak it with some anti-seize tomorrow, and hopefully this things comes apart..
Do I have to push the pin with a small punch? Or do I have to push, and hold while I separate the two pieces?
Old 06-25-2009, 06:33 PM
slacker's Avatar
chances are .. like most I have done .. the pin will be siezed .
hopefully you have a replacement lock ? , cuz you cant save it now . just punch the pin with the drift and colaps it .
Old 06-26-2009, 05:20 AM
Marc's Avatar
Sorry, I thought you meant the whole assembly, not just the cylinder.
Old 06-26-2009, 07:45 AM
874runnersr5's Avatar
Wow, so this is how you take it off...
interesting, awesome thanks!
Old 06-26-2009, 04:35 PM
slacker's Avatar
I have a bunch of pictures if you want ? I think
Old 06-26-2009, 10:28 PM
It takes a bit of work, everything is rusted on my spare one haah.
09-04-2015 09:27 AM
MTLroadierunner
07-20-2015 03:07 PM
lfcarrion3
07-18-2015 04:05 PM
hamburg99
07-13-2015 09:54 PM
AaronM
07-08-2015 07:15 PM
Quick Reply: Removing tailgate lock cylinder
