Removing front diff '92 SR5
Old 07-25-2014, 08:45 PM
Peart130's Avatar
Hey guys!
I'm swapping out front drive axles / diffs from an SR5 parts truck, to my base model pickup. Having a hell of a time getting the front diff out, have all CV's disconnected, all mounting bolts removed, and cannot seem to get the darn thing past the oil pan (3VZ motor).
Any suggestion for persuading it out would be awesome!!
Old 07-25-2014, 09:26 PM
scope103's Avatar
Have you removed the half-shafts? I've never removed the diff, but I'd take the half-shafts out first.
Or is that your problem? To remove the half-shafts, the front suspension MUST be compressed as though the truck were sitting on the tires. If you just have the front wheels dangling, the angle is wrong and the half-shafts will not come out.
Old 07-25-2014, 09:36 PM
Peart130's Avatar
Well I have the shafts disconnected already, the whole unit is loose, I can move it slightly with my mini floor jack. Seems to me that it won't move back any will not budge in any direction, as I try to move the unit toward the rear of the vehicle I hit the oil pan.
Old 07-26-2014, 01:06 AM
RJR
RJR's Avatar
Have you taken out the front cross member that the diff bolts to? With that out of the way it should come right out. Just remove the two bolts on each side that attach the cross member to the frame.
Old 07-26-2014, 08:21 AM
Peart130's Avatar
Okay, I must have missed that yesterday, I'll give it a shot today and hopefully get it out.
Thanks RJR
Old 07-26-2014, 02:08 PM
Peart130's Avatar
Got it off finally, It was that and the three bolts I missed on the passenger side frame mount. Thanks for your help!!
jerusry
10-19-2015 05:28 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
TokyoD23
07-12-2015 06:01 AM
ItsJustD
07-07-2015 07:49 AM
Quick Reply: Removing front diff '92 SR5
