Removing crank from 3.0, auto- pull engine or trans?
Old 10-19-2009, 08:08 AM
cruciform's Avatar
Hi, I have a 91 4runner that ran well, but has a rod knock, I dropped the ft diff, oil pan, etc. and found that a couple of the rod journals were scored, and the bearings toast. I obviously need either a new crank, or to have my existing crank ground..
in order to remove the crank-
Is it easier to move the engine forward, or to push the transmission back? I have a cherry picker, and a med duty floor jack.. i can buy one of those harbor freight transmission cradles for my jack, to possibly make it easier, but the thing is a bear, and being an auto, weighs a ton with the transfer case.
Any write ups on crank removal anywhere? I searched, but didn't come up with much.
thanks!
85run
07-08-2015 11:20 PM
OffroadRalph
07-02-2015 07:28 PM
ian1386
07-01-2015 11:23 AM
rbravo1
06-29-2015 01:34 PM
Quick Reply: Removing crank from 3.0, auto- pull engine or trans?
