removing bed
unscrew gas tank filler neck from bed. These screws will be tight. Remove all your wires from the tail lights and license plate light. un-bolt the 6 bolts holding the bed down. done. You can remove the plastic inner fender wells first if you want to.
basicly whathe said but you may need to cut some bolts have fun
FYI, there are 8 mounting bolts on the bed. Unbolt ( use penetrent lube to loosen them up before hand) these bolts, the gas filler neck and pull the taillight/licence plate wiring out.
2 guys can easily pick the bed up and pull it off..
I would recommend taking the tailgate off prior to moving it as one piece...makes it a bit better to remove. I removed mine with a buddy and it wasn't too bad. The bolts on mine felt like they were stripped, but in reality they spin until an arm hits a solid piece and then they loosen up. Hit em with PB blaster for a couple days prior to removal and it should help.
FS[PacNorWest]: 1982 Toyota Long Bed Trailer
58rennur4
08-04-2015 08:49 AM
DrZero
18
07-24-2015 11:31 PM
Backcountry411
07-24-2015 08:06 AM
FS[NorAtl]: 1989 pickup beds and leer cap Rhode island
mickyd9990
07-06-2015 09:01 AM
