Removed my cracked clutch bracket, and found the dash support was cracked too...
Old 11-23-2008, 01:36 PM
Fo by Fo's Avatar
On my 1991 4runner the clutch bracket was cracked. After I pulled it off I noticed that the support that is welded on to the bottom of the dash that the clutch bracket bolts to cracked as well. When I say cracked I mean completely broken, and its welded onto the body or dash. Has anyone else had this problem? this has turned into a real nightmare... I don't even know how to fix it besides welding or pop riveting it.
Old 11-23-2008, 04:04 PM
orbital02's Avatar
the same thing happened to my dads 89 p/u. He made a bracket for it and connect the clutch bracket to firewall.
Old 11-24-2008, 05:53 AM
Fo by Fo's Avatar
Was it just your main bracket that cracked, or the upper dash mounting support too?
Old 11-25-2008, 01:26 PM
Fo by Fo's Avatar
anyone?
Old 11-26-2008, 11:46 AM
jerbear's Avatar
Happened to me as well. I got the bracket at the pedal welded at a local shop for their $15.00 minimum and I removed the cowl cover drilled two hole and made stiffening brackets, bolted the whole thing together and covered it all with silicone caulk to prevent leaks. Did this over a year ago and it still works fine. I am 6'1 and weigh 350# I put a lot of force into the pedal, enough to break it, but it has stayed put since this shadetree repair. Hope it helps
Old 11-26-2008, 12:28 PM
krb90's Avatar
Had this happen to me, and did almost exactly the same repair, minus the welding (sheet metal screws). I took off the vented cowl piece and actually cut a small hole in the sheet metal where the spot welds broke. Made my own bracket and used sheet metal screws to secure it to the body. Heavy plastic stuck to the body with black roofing mastic sealed up the hole, and will never be seen through the vents, so aesthetics were never an issue. Did all that without removing the pedal bracket or anything under the dash. Still going strong at least 5-6 years.
Old 11-28-2008, 09:53 AM
Fo by Fo's Avatar
I'm in the process of making a new bracket support for the upper dash support above the clutch pedal on the clutch bracket but I'm debating between weather or not making it shaped like the old one because I don't have much surface area to drill into since the old metal ripped out when I tried to drill out the spot welds on the old support.
Old 12-21-2008, 02:31 PM
Fo by Fo's Avatar
does the insulation go between the firewall and the bracket?
kazuya2416
04-05-2024 02:17 AM
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
Johntom240
7
07-13-2015 12:18 AM
smiley52
07-11-2015 05:16 AM
Quick Reply: Removed my cracked clutch bracket, and found the dash support was cracked too...
