Removed 4Runner Top...Now Back Window Wont Go Up...
Hey everyone, I finally took my top off today. Well...I put the top back on and now my back window will not go up. During removal, the 3rd top bolt (top meaning the top row of bolts) from the driver's side broke off. Could this have anything to do with my problem? I plugged the cable back up for the rear windshield wiper and while researching my problem, I read something about a bolt located in the driver's side near the roll bar. Can anyone shed some light on this "bolt" for me? In case you were wondering, I have "searched"...I know this question probably pops up a lot. haha Thanks guys.
Location: Yotatech, because Pirate is too expensive. NorCal.
If your top is off it wont go up. There is a switch in one of the bolt holes on the bed rails. Look for it or just put the bolts back in the rails. It will go up once there is a bolt in the hole. If the top is all put back together and it still wont go up then you have a problem.
The bolt you broke should not have anything to do with the window. There is a switch in the bed on the drivers side that is tripped when the top is bolted on (or unbolted). I think it is the second bolt from the back on the drivers side. I bypassed that switch many years ago and don't remember much about it. Now I can roll up the back window with out the top. For whatever good that does.
OK...I did forget to mention that my top IS back on...I've been trying to get back on the the forum to edit that, but i've had internet problems. So yes...haha...sorry...my top is back on. Thanks for the posts though.
Yes, they have all been put back in, aside from the broken bolt that I mentioned. However, that isn't the problem I guess.
a lot of times if you tighten the bolt that hits the button you can break the button and that would cause the window to not go up. mine on the other hand has problems going up and down because the motor is crapping out and the regulator is so rusted the window doesnt stay in it lol
My trigger/switch broke so I just ran a jumper between the connection. Just remove the plastic side panels in the back and the switch can be disconnected and bypassed.
Being able to roll up the window with the top off does make it easier to wash the inside of the back window.
Sounds like that is the interlock bolt and switch (cover top switch):
- http://www.4crawler.com/4x4/4R_TechInfo.shtml#Shell
You can see how the cover top switch works below:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
Bypassing is just making the control module think that switch is closed, jumper wire across the switch or the connector should do the trick.
Take a piece of wire and crimp a spade connecter to either end (female if I recall) and then jumper the switch with that wire. I used some electrical tape to keep the wire in place and (hopefully) keep some of the dust out of it.
Excuse my ignorance, but could you please explain how you bypassed it? I did remove the panel and found that switch you mentioned.
Hhhhmmm...thanks guys. Today a buddy of mine (the same guy who helped me fix my brake lights) took a look at it and he thinks the problem is actually coming from the switch in my center console. When he tested it, he couldn't get any power. On the way home from work tonight I did notice that the button was not lit up (yes its plugged in). By some miracle, I think I have found a junk yard that has an '87 4Runner in it, so I'll be stopping by there Wesnesday. One thing is for sure...I'm getting tired of driving around with a trash bag taped over my back window...
