remove crankshaft pulley (not the bolt)
I got the bolt off no problem by putting the truck in 5th and having my wife stand on the brake.
Any tips on getting the pulley itself off? I can't get leverage on anything to pry it off, does anyone have any tricks?
A steering wheel puller works great if it's really stuck after hitting it with a penetrating oil like PB blaster.
Here's one example:
http://www.harborfreight.com/46-piec...set-37824.html
Your local auto parts store may have a kit like this that they loan for a deposit fee.
Here's one example:
throw a gear puller on there!! hell, if it bends, i always like to say "man made it, man can fix it"
you can always find a new pulley, its good to get one off without damage, but if you cant, theres plenty of spares. stuff happens man, what the heck ya gonna do?
actually, while ur pulling it with the puller, apply LIGHT pressure, and then apply heat at the same time. something stronger then propane, and lighter then oxy-acetylene. maybe map gas?
if it's that tight you might wanna order some new crank keys as well. I had that problem as well, had to use a puller the first time. It was because as some point the P.O. damaged those crank keys. 3vze only needs 1 according to LCE.
One of the few things I would order from LCE: http://www.toyotacatalog.net/M1WebGe...7-D468AD6C4C1D
Blamalam
03-12-2022 07:34 AM
TJWilly
07-31-2015 02:05 PM
dinks07
07-15-2015 05:34 PM
